Need help identifying this (double?) diode
  • repair-it
    replied
    Thank you for the replies, seems to be fine once I tested it out of circuit.
  • truclacicr
    replied
    MBRD360, 3A, 60V, single Schottky barrier rectifier:
    https://docs.rs-online.com/3644/0900766b80032d37.pdf
    The top line is a date code.
    https://www.google.com/search?imgtyp...Cisz%3Am&udm=2
  • CapLeaker
    replied
    nuttn much, but a plain Schottky 6A 40V common cathode ultra fast diode.
  • repair-it
    started a topic Need help identifying this (double?) diode
    I tried to locate online without any success but maybe someone else might have better luck. If it is a double diode - it's done - based on the reading I got in diode mode.
    Premium supporters get full download access and other benefits.
  • Baste
    MBR3045CT and SR3045LCT Schottky diode testing help.
    by Baste
    Hello experts,
    Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
    Aneng ST182 Meter.
    Diode mode.
    MBR3045CT:
    Diode mode
    Pin 2-1 - 0.150v
    Pin 2-3 - 0.150v ...
    10-21-2025, 06:14 AM
  • iyas132
    Corsair RM 750 blown schottky diode near ES1DF
    by iyas132
    Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
    Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
    My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
    Can anyone help me identify the component...
    12-30-2024, 01:34 AM
  • magneh
    Help identifying diode - ST Microelectronics marking EUV C730
    by magneh
    Hello all!
    could someone help identifying this ST diode?
    Marking EUV C730
    Photo attached,
    Thanks in advance!...
    01-22-2025, 09:08 AM
  • DennisH
    Need Help Identifying This DIODE mounted on a Frigidaire oven control PN:316131600
    by DennisH
    This diode is mounted on a Frigidaire electronic oven control PN:316131600. This diode runs hot enough that the PCB is showing slight burn marks (black soot looking area on PCB above the diode). It looks to me to be coming from the body of the diode.
    The oven control is 22 years old and still works, but I can't get a new replacement, so I'm doing preventative maintenance and replacing a few parts on it that I think could fail - and this is one of them.
    Can any of you identify this diode (see pic) and suggest a replacement that can handle more heat - or if not, can...
    10-18-2022, 07:24 PM
  • Donny2derby
    Help identifying shorted diode.
    by Donny2derby
    Hi there all.
    Troubleshooting an SMPS and I’ve found a SMD diode shorted in both directions. The trouble is it has no identification on it. So what do I replace it with and how do I tell where the anode and cathode is and how to mount the replacement?
    It is diode D1 on the image.
    Regards.
    Gareth....
    03-07-2024, 08:10 PM
