Can someone please help me identify this resistor?
  • mitsu2k
    • Aug 2013
    • 219
    This is out of a Pridiom mini split unit. It is the power board. This component is completely charred however I was able to get a photo from a good board.
    I know it is .015 ohms and 1% tolerance but that’s about it.
    Thank you!!
  • truclacicr
    • Apr 2019
    • 352
    • australia
    https://www.google.com/search?imgtyp...Cisz%3Am&udm=2
    DALE WSR-5, 5 watt, 1%
    https://www.vishay.com/docs/31059/wsrhighpower.pdf (datasheet)
    http://www.vishay.com/doc?30327 (markings, see page 2, top right)
    • mitsu2k
      • Aug 2013
      • 219
      Thank you @truclacicr
      I was able to find that info. Just having trouble finding the part number to order on Mouser
      • mitsu2k
        • Aug 2013
        • 219
        Yay I think I found it. Part# WSR5R0150FEA
        • truclacicr
          • Apr 2019
          • 352
          • australia
          WSR5R0150Fxx, where xx = EA, EK, TA or BA
          • lotas
            • Jan 2016
            • 4818
            • Russia
            This powerful current resistor does not just burn out, check the three-phase power module for powering the compressor, there should be no short circuit or low resistance on these terminals.
            • lotas
              • Jan 2016
              • 4818
              • Russia
              Since you don't have a resistor now, check it like this.
              • mitsu2k
                • Aug 2013
                • 219
                Thank you Lotas, I did check as you mentioned. I did not find any short circuit or low resistance across those terminals. However there are a bunch of bloated caps. I will be replacing them.
                Edit: sorry, I take that back. There is a short between the “P” and “N” see last photo terminals. Any ideas?
                • mitsu2k
                  • Aug 2013
                  • 219
                  I cannot find any other shorts on the top side of the board. There is a large chip on the bottom side however. I have no idea what it is or how to test it. See photo.
                  • lotas
                    • Jan 2016
                    • 4818
                    • Russia
                    Check between the three common terminals (-) and (+) bypassing the resistor, if there is a short, replace the module or look for a donor (the board itself), since the module can take the control processor with it...
                    • mitsu2k
                      • Aug 2013
                      • 219
                      Ok I checked between (+ P) and the 3 common terminals and there was no short or low resistance between them. I also did the same between the (-N) and there also was no short or low resistance.
                      the only short seems to be between the +P and the -N.
                      is this normal?
                      hold on. I think I did it wrong. There is a short from P to one side of the resistor pad and also a short between the N and the same resistor pad
                      • mitsu2k
                        • Aug 2013
                        • 219
                        Also I noticed on the processor one of the legs must have gotten really hot. There is some solder that looks to have melted out of the through hole and onto the leg. See photos
                        • lotas
                          • Jan 2016
                          • 4818
                          • Russia
                          That's strange, then check this metal film capacitor, unsolder it.
                          • lotas
                            • Jan 2016
                            • 4818
                            • Russia
                            Measure here again, this leg is +300v and the resistor that burned out passes through it -300v and this power supplies this IGBT module.
                            • mitsu2k
                              • Aug 2013
                              • 219
                              I would love to unsolder the metal film cap however the pins are directly underneath the processor chip. I would have to remove that first and it looks like it would be a nightmare
                              • mitsu2k
                                • Aug 2013
                                • 219
                                Ok measured between the pins you specified on the IGBT module and there is no short. I am reading exactly 135ohms between the one leg and to each of the 3 others
                                • lotas
                                  • Jan 2016
                                  • 4818
                                  • Russia
                                  This is not a processor, but a power IGBT module, and this processor, which controls this module, when this module breaks down, it sometimes kills this processor, then that’s it, only the replacement of the entire board.
                                  • lotas
                                    • Jan 2016
                                    • 4818
                                    • Russia
                                    This shouldn't happen, which means the module is faulty.
                                    • mitsu2k
                                      • Aug 2013
                                      • 219
                                      What should I expect to see between them under normal conditions?
                                      • mitsu2k
                                        • Aug 2013
                                        • 219
                                        I think I’m understanding now. So likely the IGBT module shorted, causing the current sense resistor to burn. Also this IGBT shorting also may have possibly caused the processor to go out.
                                        • gica69
                                          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                                          by gica69
                                          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                                          Resistor shows orange range silver gold and green lines.
                                          Thanks in adv...
                                          07-21-2025, 09:49 PM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • sikocan
                                          Identify resistor R802 PS4 Pro PSU
                                          by sikocan
                                          Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
                                          11-01-2022, 07:33 PM
