can bypass damage vreg
  • harp
    • Jun 2022
    • 616
    • Planet Earth
    Does occasionally connecting the input and output do any harm to the voltage regulator?
    • 31144
    no, you just risk blowing the hell out of the parts it powers!
    • harp
      • Jun 2022
      • 616
      • Planet Earth
      Thank you, I am not worry about that... I seek for elegant solution to modify ch341a to program 5V ic like 93xx, 95xx, so I just put jumpers over 3.3v and 5v headers pin...
        • 31144
        well:
        • harp
          • Jun 2022
          • 616
          • Planet Earth
          So, I am inventing hot watter... I see some video where is doing ugly modification to bring 5v to ziff... BTW, for 3.3v mod, I would rather use thin wire and insert piece or two of kapton tape between leg and pcb then lifting it so high... if anytime ahead the leg has pushed down again, it would break...
            • 31144
            i slipped capton under it and linked it with kynar wire
            then put a dab of rtv silicon on the pin
            • Spudgun
              Why doesn't current just bypass faulty capacitors.
              by Spudgun
              Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
              04-01-2025, 10:33 AM
            • Joel Ohana
              Lenovo IdeaPad 3 15IAU7 that suffered water damage
              by Joel Ohana
              I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
              Symptoms:
              • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
              • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
              What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
              03-06-2025, 11:25 AM
            • azozexd
              Need help hp 725 g3 liquid damage
              by azozexd
              Hello freind i have hp elitebook 725 g3 White liquide damage
              after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
              could some one tell me the value of this resistor
              Thank you...
              12-15-2024, 06:01 PM
            • Arshad alam4659
              a1466 smc bypass
              by Arshad alam4659
              what is smc bypass and how does it work and how to bypass it i want to know can anyone tell me about it
              11-09-2024, 08:22 AM
            • oxonater
              Apple MacBook Pro A2141 16" IC BYPASS
              by oxonater
              Hi everyone hope all are well
              I need a little expert advice on a issue I have and seeing as this forum is full of clever people I thought ask here as you never know.
              I recently repaired a logic board 820-01700 which belongs to a 16" 2019 Macbook Pro, however I seem to be missing a component near the T2 Rom chip and is U4730.
              The schematics say this chip is (M34128-FCS6_P/T) and it also says there is a bypass for it wondered if anyone come across either the IC or the bypass method.
              I suppose it's worth noting googling the part package brings up various...
              10-23-2024, 11:21 PM
