Component identification
    Hi
    I cannot find any information on an sot-23 component. It is on a USB board. The markings are 23AX
    There is another sot-23 component next to this one and the markings are 1AM. I have found some information on this one but no information about substitutes
    If anyone has any ideas, please tell me.
    thanks so much
    i've found this:
Name:	Screenshot 2025-05-09 140949.png
      Most likely it's mosfet.
        Originally posted by Robin21 View Post
        i've found this:
        И как в этой схеме будет играть эту роль MicroPower Microprocessor Reset?
          i've found this:
          Thanks but the markings are wong
          According to datasheet
            Seems so but which one and what substitute can I use
            Also what kind of scrap boards can these be found
              Some google and using google translate
              I found
              si2301
              irlml6402
              Could these be the same
                P- channel - AO3401, AO3407...
                  I found this
                  https://world.taobao.com/item/718073032302.htm
                  This shows it is si2301
                  Is si2301the same as or equivalent to AO3401, AO3407
                    It has a lower amperage, and what about yours, is it broken (all terminals are shorted)?
                      It is connected to the USB port and the USB port current is very low
                        So maybe the problem is not in it, what does the multimeter show on its terminals, what is the resistance between the terminals?
                          I think it has a burn mark on it but I am trying to test
