Adding in a new breaker panel
  • pentium
    • Mar 2006
    • 2778
    with the new addition to my family (An SGI Onyx, Crimson, Indy, and Indigo2)
    I realize they my room will no longer cut it. I need to move.
    My first choice is Our storage room. It was an addition to our house and excluding the wall of the house all the walls are concrete and the room has the walls and ceiling insulated. The only problem is that there is a ruptured vapor barrier and the floor can get wet (not to the point of getting your feet wet but boxes go soggy over time).
    Anyways, To power my systems I need to add another breaker panel since the current one has been framed in and drywall will have to be cut in order to cater for my addition. It also lacks enough blank spaces for the new breakers.
    Attached is a rough layout of what I am planning.
    Besides a new panel for both 120 and 220V service (Probably loooking at a 60 amp panel but it depends on what's installed in the two deskside systems so I'm assuming they are maxed systems) I also plan to install a second and personal hydro meter to see just how much current I am drawing. It is rated for 100A max throughput and accepts both 120 and 220 volts.
    You can also see that the new panel is essentially on the other side of the wall.
    Question 1:
    Should I use conduit to go from the new panel, to the meter and then to the existing panel?
    Quetion 2: Would it be wise to install a master disconnect between the existing panel and the new meter to isolate and lockout my addition if needed?
    Question 3: I can get hold of a Pushmatic breaker panel as well as breakers. Should those be used or is it better to use toggle breakers?
    BTW, my parents say I have to pay for all the supplies and they need to be in code or else they won't allow it.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Adding in a new breaker panel
    If you're going directly into the meter, the power company is going to have to be involved, and you'll have to pay for a service upgrade to support the additional panel.
    Ludicrous gibs!
    • pentium
      • Mar 2006
      • 2778
      Well I was thinking more along the lines of hooking up to just after our main breaker, then if the whole house needs to be shut off (Or you try to reset a tripped dryer circuit before you find the fault) then power can still be cut at the main. Since both desksides won't (and with an interlock, can't) be on at the same time there won't be an overload problem.
      I'm trying to keep within our maximum service load.
      Find Nedry!
      • shadow99
        • May 2007
        • 24
        In my province, (Sask) all electrical work done by a homeowner is "supposed" to be inspected, and I've had that done anytime I've done any wiring. A few yrs ago I wired in another breaker for a garage I built. I ran it thru the wall and underground to the garage from the house. I also wired the garage. I followed the code book and did exactly as it specified. The code book says the trench was to be open so it could be checked for proper depth, etc. The inspector checked it out and I pointed out that the trench was regulation depth, etc. and he simply said that if I as the homeowner wants to endanger the people in the house, that's up to you. So you really have to screw up bad before you'd fail an inspection, or even to have them care alot.
        Anyway, my main box had space so I simply added the breaker (push in toggle type) connected the wire and ran it out the wall to the garage. As far as the box is concerned, that circuit is just like any other circuit in the house. I did put a sub breaker box in the garage and divided it into 2 circuits.
        Before doing any wiring you should pick up the latest code book and follow it. As for the inspection that's up to you. And dont forget to cut the main power, and check the points you'll be handling with a volt meter to be sure they arent live before touching anything!
        • howardc64
          LG 49UJ6500 LCD panel lighter band that goes away
          by howardc64
          49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
          Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
          02-19-2023, 12:13 AM
        • triplefour
          SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
          by triplefour
          TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
          tcon is built into mainboard.
          Only one cable goes to panel boards.
          there is a cable from one panel board to the other that links them.
          cost cutting measure that results in us having harder time to diagnose.
          removing the link to the second panel board allows TV to stay on with stable backlight but no image.
          used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
          07-28-2022, 07:59 PM
        • Storyteller12
          QN55Q60R Service Menu Panel Help
          by Storyteller12
          I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
          I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
          I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
          the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
          01-13-2024, 01:57 PM
        • maneatingmonkey
          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
          by maneatingmonkey
          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
          03-27-2024, 07:17 AM
        • KYBOSH
          Samsung UN50TU8000 - Dead Panel Forensic Questions
          by KYBOSH
          I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
          When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
          When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
          Later I checked for shorts on the panel PCB boards but could not find anything.
          When I took a look with the FLIR i noticed the 2 resistors...
          08-10-2024, 08:39 AM
