IC Identification - HELP!
  • fichamba
    • Dec 2011
    • 131
    • Spain
    Hello everybody:
    I’m having problems identifying one QFN17 component in an Asus laptop MoBo. I know there are no schematics for this model, nor boardview. I’ve looked thru all internet and I still don’t know which component is this (I attach a couple of pics with both the component and the laptop model, s/n, etc.).
    Thanks in advance for your invaluable help.
  • truclacicr
    • Apr 2019
    • 306
    • australia
    APL3530QFI-TUG
    https://www.aliexpress.com/w/wholesale-l3530-qfn.html
    It could be an Anpec load switch.
    • fichamba
      • Dec 2011
      • 131
      • Spain
      Originally posted by truclacicr
      APL3530QFI-TUG
      Thanks a lot, truclacicr! Indeed it is! For its position in the circuit, it’s a load switch (it reaches >200°C!).
      There are 3 units in the MoBo, one for 3.3V., one for 1.8V., and this one for 5V. There are only around 28 ohms to GND, but in spite of this, this load controller does its job. It’s curious, because the another two marked a “thermal peak” in the very start of the laptop (looking thru a thermal camera), and immediately became cold. But this one remains extremely hot.
      I need to investigate a bit more in order to discover this low resistance load.
      • fichamba
        • Dec 2011
        • 131
        • Spain
        JFYI, the problem is the load switch itself. Once removed, I measured short between the two big contacts, and even between any of them to ground pins. So now I’m waiting for AliExpress…
        Thanks again!
        • mojos911
          Fisher and Paykel 10 kg top-load washing machine LED identification
          by mojos911
          I'm looking for a replacement for the red LEDs used in a Fisher & Paykel 10 kg top-load washing machine. Each LED is about 6 mm long, mounts flush to the PCB with side tabs, and measures around 1.7 V forward voltage in diode-test mode. The marking on the body is “3A56,” but I can't find any matches for that in part searches. I've attached photos to show the shape and mounting style.
          If anyone has sourced an equivalent or knows a suitable replacement, I'd really appreciate your input. Thanks in advance for the help!...
          01-17-2025, 06:54 PM
        • AJ847.63e
          Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
          by AJ847.63e
          Hi Folks,
          Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
          I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
          The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
          05-06-2025, 10:37 PM
          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
          09-12-2024, 02:20 PM
          HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
          This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
          09-06-2024, 10:56 AM
          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
