Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
Linear Garage Door Opener Control board took a crap install a new control board back normal
    • Jul 2011
    • 6093
    • Soldering Junkie
    I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that was the red but the green one was off
    I have had another opener that is the same model number that got stuck by a near by thunderstorm that took out the control board but I keep it because the motor still works so I have spare parts for this one if the motor goes bad
    Premium supporters get full download access and other benefits.
    • Jul 2011
    • 6093
    • Soldering Junkie
    Well the new controller did the trick it is behaving itself the way it should and being a pain in the a** like it was
    • redwire
      • 3962
      Was the garage door just stopping or does it stop'n reverse by itself? You have to be careful with what is going on with the garage door opener.
      When the door is closing, it will only reverse if there is an obstacle in the safety beam, or high torque is detected. Count the number of light flashes (high torque squished the cat =4, or safety beam =3).
      If the door just stops mid-travel, it was the remote control receiver falsely detecting another button press.
      I had this problem a lot where the door would start to move, then stop. It's the remote signal being too weak and a long press is seen as two short presses.
      Linear LDO50 door opener control board, HAE00040 or older is HAE00039.
      The control board remote control receiver has a tuning adjustment. Likely the remote has one as well. These drift with getting banged around, or with cold weather as well I find.
      It's got an optical speed sensor in the black ring, which is used to sense high torque. Three relays, one for UP, DOWN, LIGHT. Zettler AZ943-1CH-12DE.
      Once I had a bad relay cutting out and the motor stopping sometimes.
      I guess you could repair the old board if it's worth it.
      I will do a recap, change the relays and check remote tuning and then it's all good.
        • Jul 2011
        • 6093
        • Soldering Junkie
        I thought about trying to repair but it has two issues one the obstacle sensor on the side that has the red and green lights only the red one was turning on but not the green one and it would travel about a foot then trip out and reverse sometimes
        One other thing it was doing was not receiving the signal from the remotes like it should either you almost had to be next to the door for half way work this took about a year for it to get to that point
        When I installed the new controller board everything worked perfectly fine like it did when it was new
        I am not sure if it is worth the time and effort to try to fix it
        • redwire
          • 3962
          It's worth it when the model is discontinued and prices for a control board etc. go crazy expensive. How much is a new board?
          Your old board has some power supply or data problem, these are running 24/7 and the caps do wear out so power to the obstacle sensors must be bad or maybe it's lightning again.
            • Jul 2011
            • 6093
            • Soldering Junkie
            To answer one question about the cost of a new board it is $114.00
            Maybe a capacitor issue but there might one or two but I do not remember of the top of my head how there are
            As far as the obstacle sensor is concerned it has been working fine with the new controller board
            so I do not think there is an issue with it I think the hole problem is with the controller
            As far as it being hard to find a replacement controller board this does not seem to be an issue right now but I will from time to time look and make sure that I can still find them
              • Jul 2011
              • 6093
              • Soldering Junkie
              Well the original control board was struck by lightning ( hit a tree which the bark was blown off a good portion of the bottom on one side of it ) that hit near the house again this is about 5 or 6 time that this has happened since I have lived in this house that explains why the door sensor was not functioning correctly I am glad that I decided not to try to fix this control board for this garage door opener because it does so much damage to the circuit board devices that I have found in general is a waste of time and money to try getting it to work properly again
              • CapLeaker
                Leaking Member
                • 8747
                If this is a regular thing getting hit by lightning, why not install surge protection?
                  • Jul 2011
                  • 6093
                  • Soldering Junkie
                  It seems to attack the obstacle sensor circuit and any other device that in the area on the circuit board I have to wonder if this would really make that much difference because at one time I had a hole house surge protector and I still had issues when lighting strikes near the house so I not sure what would really help
                    Linear Garage Door Opener Control Board Repair weak capacitors
                    by sam_sam_sam
                    I was having issues with the controller not always responding to remote control signal having to hold button until garage door started to move
                    Now after replacing the two capacitors on the two 5 volt power supply rails
                    One is used for the up/down limit up/down force circuits
                    Second one is used for the radio receiver circuit
                    The main filtering capacitor ESR value was a little higher than a new one
                    https://www.northshorecommercialdoor...yABEgLxlvD_BwE
                    09-03-2022, 12:15 AM
                    Lift Master garage door opener with WiFi capability application through your phone
                    by sam_sam_sam
                    I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                    This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                    01-21-2023, 08:31 PM
                  • CoinCoin88
                    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                    by CoinCoin88
                    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                    09-15-2025, 03:36 AM
                  • Cornboats
                    Garage door opener-safety cutout faulty
                    by Cornboats
                    I have vintage Slavedor garage door opener that has stopped closing the door. If I disable the up/down current control to the motor it works fine. I've attached the larger control board which is for everything and the smaller current control board.
                    Normally the current control is set slightly above the maximum current normally used. If the door exceeds this it should stop and reverse when closing or just stop when opening. Can someone please explain how the current control board works so that I can try and repair or replace the defective parts.
                    I see my self as an interested novice...
                    01-19-2023, 05:25 AM
                  • harp
                    UNI-T UTP3315TFL-II (2025) Linear PSU review
                    by harp
                    Review of UNI-T UTP3315TFL-II (2025) 30V 5A linear PSU A laboratory power supply is one of the essential devices a DIY hobbyist should have, whether built or purchased. The internet is full of schematics from experienced electronics engineers showing high-quality power supplies with various features that differ from commercial products. In my case, I also used various "adapters" — power supplies from different devices such as mobile phones, laptops, and similar — sometimes combined with Chinese voltage and current control modules. While doing that, I was also gathering schematics...
                    06-30-2026, 10:35 AM
