What Caps are these?
  • Y-3
    • May 2007
    • 6
    What kind of cap are the yellowish gold ones on the left (16 of them)?
    going to change the audio capacitors on my soundcard and is still wondering which one to get.
    the stock ones on the soundcard = Jamicon 22uf 16v
    should i get Blackgate standard 22uf 16v or these gold ones or just short them?
    read about it that no caps on audio path would be best, it may not be stable however.
    can someone exprienced with modding soundcard give me some advise?
    thanks
  • tazwegion
    • Jun 2006
    • 444
    Re: What Caps are these?
    Hmmmm... Blackgate are highly regarded (and expensive) components, you do of course realise changing said capacitors will forever alter the sound reproduction of the card?
    AFAIK Elna also make reasonable sound card quality capacitors
    Viva LA Retro!
    • Y-3
      • May 2007
      • 6
      woh thanks Taz. elna "audio capacitors"
      the sil II has 22uf 16v ones. gonna find out how much they are 1st.
      anyone happen to know which are the power supply capacitors for the opamp on this card?
      • shadow
        • Feb 2007
        • 732
        Bright yellow caps always remind me of Fuhjyyu which is known as a bad cap manufacturer. However that does not say that there are Fuhjyyu's unless you can read that on the side of them.
        You should check out Logistics posts in the audio equipment section on this forum. He posted some stuff about recapping Sound Blasters and performing various other tweaks to them.
        • Logistics
          • Apr 2007
          • 721
          Looks like a modded X-Fi with alternative output opamps. Did you find that on the Head-Fi forums?
          The trouble with cards like this is there simply isn't room to be throwing in appropriately sized film caps on every channel. The card becomes a compromise. There is a huge difference between the best electrolytic cap you can use for audio and the best cap you can use for audio. Due to the cards multi-channel nature, space becomes a huge concern so it's reasonable to just use the best electrolytic you can. However, each of the electrolytics in the signal path should still be bypassed with a .1uF film. This will result in better high frequency characteristics, though the electrolytic will still crud up the sound quite a bit.
          As far as removing the decoupling caps from the signal path and just shorting the traces, yes, in some situations this is technically better. However, if you are using headphones directly off the card, you don't want to do this as it can damage your headphones. If you're outputting to an external piece of equipment like powered speakers or an amplifier, they will likely have their own decoupling caps on their input stage so it won't matter. Not all opamps are designed to run this way, however. I know on my Live! it was not possible to directly couple the DAC and output opamp.
          Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
          • Y-3
            • May 2007
            • 6
            thanks logistics
            • cap__
              Can I replace 15uf capacitor with 22uf?
              by cap__
              "If I wanted to replace an old 15uF/400V capacitor with a new one,
              I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
              11-29-2023, 11:16 AM
            • Cory Marqusee
              MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
              by Cory Marqusee
              Hi Everyone,
              I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
              How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
              I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
              09-15-2022, 02:03 PM
            • Jason616
              22uf 250v non polarized cap
              by Jason616
              I cannot find these anywhere .
              Does anyone know where I can purchase theses caps ?
              I'm very limited on space so I cannot make my own out of 2 polorized caps nor use a polypropylene cap since it's package size is to big to fit in the allowed space.
              So wondering if anyone has any info on where I can purchase the following caps
              22uf 250v non polarized radial leaded capacitors
              11-27-2021, 01:18 AM
            • SwedishDiesel
              Mystery Nichicon 22uf 25v Caps
              by SwedishDiesel
              Howdy folks,
              The GX260 strikes again, I just now noticed that a bunch of smaller caps on the motherboard are bad.
              There's no indication of what series these are, but they have the same color wrap as the HM series. They're rated at 22uf and 25v and about 5mm x 6.5mm. The only other markings are the temperature rating (105 degrees Celsius) and what I assume is a date code - A236. The data sheet for the HM series doesn't include caps with these ratings. I've attached some images of the caps themselves and where they are/were on the motherboard.
              Does anyone...
              11-18-2021, 08:54 PM
            • Keshenatech1
              WS-WN523N2 WiFi AP Power Supply
              by Keshenatech1
              I had been using a WS-WN523N2 to generate WiFi from my wired ethernet internet connection. Recently it needed to be power cycled more and more frequently so I decided to open it up. I found 2 bulged 470uf 16V capacitors in the low voltage output side of the unit's power supply. The 2 other capacitors in the high voltage side, a 4.7uf 400V and a 22uf 100V both read low ESR so I decided to replace them as well. The 4.7uf 400V is directly across the output of the full wave bridge and the 22uf 100V is on the other side of an inductor coming off of the positive side of the bridge, negative side directly...
              02-16-2023, 01:33 PM
