Changing mosfet different brand same value
  • julianmustofa
    • Dec 2021
    • 39
    • indonesia
    Hi.. i got a laptop with shorted highside mosfet
    its NTMFS4C06N 30V/69A
    i only have SM4336NSKP 30V/65A laying arround
    it is okay to change with different brand?
    i just worried its not compatible with pwm controller. The pwm controller is RT8819AGQW
    thanks
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
  • Nooy
    VGA MOSfet permanently shorted and loss of MOSfet pad
    by Nooy
    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
    02-14-2024, 02:26 AM
  • redbaron1007
    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
    by redbaron1007
    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
    09-09-2025, 11:10 AM
  • AppleLover123
    Asus X712EA 3 volts after the first mosfet
    by AppleLover123
    Hey guys,
    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
    Now i thought something...
    12-15-2024, 07:49 AM
  • MicroSMD Lab
    by MicroSMD Lab
    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
    01-10-2024, 06:36 AM
