Boost ZK 4KX low output damaged?
  • marce002
    • May 2018
    • 316
    • Argentine
    Hi
    This device is a common buck boost 0v to 30v...
    It was working good now shows close to 0V output whatever Volt I set. The unit is powered from good amps 12v server power supply. I took appart and shows no phisical damage... mosfet looks fine ..what can i try? see pics:
    thks in advance!!
    Marcelo J
  • marce002
    • May 2018
    • 316
    • Argentine
    Changed the mosfet, and problem still there. sad
    Marcelo J
    • truclacicr
      • Apr 2019
      • 316
      • australia
      Check FP5139. Is it being turned on (BR/CTL)? Does it have a Vcc supply?
      https://www.insidegadgets.com/wp-con.../07/FP5139.pdf
      • marce002
        • May 2018
        • 316
        • Argentine
        thks ... it seems low v ..(tested with output enabled 5v 3A , display showing 0.67v 2.92A no load!!) and in 5139: 0.369v in vcc pin and 0.249v in br/ctl... will check who gives vcc to ir right?
        Marcelo J
        • marce002
          • May 2018
          • 316
          • Argentine
          nope, the source power is from 7550 regulator and his output to the FP5139 is exactly 5V, so the problem is in the "load side", what else can I test...? or maybe fp5139cis fried?. thks again!
          Marcelo J
          • truclacicr
            • Apr 2019
            • 316
            • australia
            If BR/CTL is low, then the FP5139 is switched off (disabled).
            • marce002
              • May 2018
              • 316
              • Argentine
              As i stated before i have 0.249v in br/ctl... so maybe should desolder it and test if shorted ?
              Now i realize that seems to be D8 shorted.
              Marcelo J
              • FrancescoV
                Onkyo HT-R390 no sound output, video output ok
                by FrancescoV
                Good morning everyone,
                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                The firmware reported is the following:
                M:1.00/11107BLP
                D:?.??/????????
                O:1.00/11107AL
                The DSP firmware given the question marks seems corrupt.
                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                05-11-2025, 02:59 AM
                HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) Specification for Upgrade or Repair
                This specification for the HP EliteBook x360 1030 G3 + Samsonite Base Boost Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Samsonite Base Boost boardview and 1030 G3 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                09-06-2024, 09:00 AM
                HP EliteBook 850 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                This specification for the HP EliteBook 850 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 850 G5 + Samsonite Base Boost boardview and 850 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                HP EliteBook 840 G5 + Samsonite Base Boost Notebook 800 Specification for Upgrade or Repair
                This specification for the HP EliteBook 840 G5 + Samsonite Base Boost Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsonite Base Boost boardview and 840 G5 + Samsonite Base Boost schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
