piezo worn out issue
  • harp
    • Jun 2022
    • 624
    • Planet Earth
    I wonder if it is real, or missleading some other problem? ?............... https://m.youtube.com/watch?v=ceb09rxPohA ?....... in video is presented claims that new piezo fix problem of poor production of moist, what is electronic science stand behind that conclusion? Can piezo be worn out and hot to tested it for that condition.............. in the past I see video where is piezo torturing through test vith high voltage, various frequency, and it is amazing what can survive and operate after damaged.
  • harp
    • Jun 2022
    • 624
    • Planet Earth
    https://m.youtube.com/watch?v=-G16BPb2PKw ?.................. Piezo Speaker vs 1000v
    • CapLeaker
      Leaking Member
      • 8327
      nothing surprises me in that vid. He probably bought it on Wish.
        • 31204
        piezo elements can fail for several reasons.
        drive them card enough and the ceramic wafer can crack,
        if they get really old the silver layer can tarnish and flake off,
        and if they get wd40 or some other things on them the silver layer can flake off.
        NEVER solder to them without solder that is atleast 5% silver or it will desolve the plating btw.
        • harp
          • Jun 2022
          • 624
          • Planet Earth
          Yes, the video dont explain too much, but on many places people have same problem, and on some they claim that replacing piezo fix it... https://www.shroomery.org/forums/sho...umber/27864401 Short stoty... Before a few years ago I was received a ultrasonic difusor to repair, the fault is described like "first few seconds produce mist, than rapidly reduce, still working (boubling in bath) but nothing mist came out...".................. http://www.youtube.com/watch?v=jJS8D6AHpOs ...from that description, I only briefly check with water in bath if they initialy work (and it was), and promptly open device for measurement (so I do not check for fully initial claims in fault description)....... I see nice burned pcb behind mosfet, but mosfet is reading good with dmm and transistor tester. I managed to make a copper heatsink on it, and after assembled I tested over 8 hours in continuity, full power, where hour by hour got stable production of mist about 30g/h, stable temperature in bath and on mosfet heatsink (no any noticable heating)............... So, I think that simptoms is connected with previous overheating of mosfet, and belive that I fix device, certainly I have proof because filming video, where is mist produced flawlessly............... But, after transport back I got information that nothing changed, same fault description............ Because device is from my friend, he send me device again and tell let it keep it for myself. I now collecting information, because, after cleaning it well (with water, vineger, its clean like new) I can confirm the original fault description, and can not understand what happend to it that in some case work ok, and in some not... If the piezo is worn out, why initialy work well? I am sorry for the mess, from recently I cant quote properly... https://www.badcaps.net/forum/genera...28#post3474728
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
          • ahmarzo
            Acer laptop battery draining issue
            by ahmarzo
            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
            08-02-2025, 06:39 AM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
