piezo worn out issue
  • harp
    • Jun 2022
    • 598
    • Planet Earth
    I wonder if it is real, or missleading some other problem? ?............... https://m.youtube.com/watch?v=ceb09rxPohA ?....... in video is presented claims that new piezo fix problem of poor production of moist, what is electronic science stand behind that conclusion? Can piezo be worn out and hot to tested it for that condition.............. in the past I see video where is piezo torturing through test vith high voltage, various frequency, and it is amazing what can survive and operate after damaged.
  • harp
    • Jun 2022
    • 598
    • Planet Earth
    https://m.youtube.com/watch?v=-G16BPb2PKw ?.................. Piezo Speaker vs 1000v
    • CapLeaker
      Leaking Member
      • 8126
      nothing surprises me in that vid. He probably bought it on Wish.
        • 30985
        piezo elements can fail for several reasons.
        drive them card enough and the ceramic wafer can crack,
        if they get really old the silver layer can tarnish and flake off,
        and if they get wd40 or some other things on them the silver layer can flake off.
        NEVER solder to them without solder that is atleast 5% silver or it will desolve the plating btw.
        • harp
          • Jun 2022
          • 598
          • Planet Earth
          Yes, the video dont explain too much, but on many places people have same problem, and on some they claim that replacing piezo fix it... https://www.shroomery.org/forums/sho...umber/27864401 Short stoty... Before a few years ago I was received a ultrasonic difusor to repair, the fault is described like "first few seconds produce mist, than rapidly reduce, still working (boubling in bath) but nothing mist came out...".................. http://www.youtube.com/watch?v=jJS8D6AHpOs ...from that description, I only briefly check with water in bath if they initialy work (and it was), and promptly open device for measurement (so I do not check for fully initial claims in fault description)....... I see nice burned pcb behind mosfet, but mosfet is reading good with dmm and transistor tester. I managed to make a copper heatsink on it, and after assembled I tested over 8 hours in continuity, full power, where hour by hour got stable production of mist about 30g/h, stable temperature in bath and on mosfet heatsink (no any noticable heating)............... So, I think that simptoms is connected with previous overheating of mosfet, and belive that I fix device, certainly I have proof because filming video, where is mist produced flawlessly............... But, after transport back I got information that nothing changed, same fault description............ Because device is from my friend, he send me device again and tell let it keep it for myself. I now collecting information, because, after cleaning it well (with water, vineger, its clean like new) I can confirm the original fault description, and can not understand what happend to it that in some case work ok, and in some not... If the piezo is worn out, why initialy work well? I am sorry for the mess, from recently I cant quote properly... https://www.badcaps.net/forum/genera...28#post3474728
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
          • Simone Vergani
            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
            by Simone Vergani
            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
            To assist with troubleshooting, I'm attaching two power circuit schematics:
            • Power
            03-05-2025, 02:25 PM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
