router troubleshooting
  • Longbow
    • Jun 2011
    • 623
    Re: router troubleshooting
    That would be a pain if this IC were really only available in China. It might be an off-the-shelf part available from Mouser or DigiKey with a different number stamped on it. This company seems to carry them:
    http://www.americaii.com/en/home/Par...htext=RT9202CS
    Is it plugged in?
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      References on Google point to a company called RichTek\CheerTech which seems to be a Taiwanese\Chinese company so I am not surprised if you can only get it from China.
      -David VanHorn
      • clearchris
        • Dec 2013
        • 687
        America II: request a quote. Yikes.
        Ebay to the rescue. I got 10 chips for 4.50$ shipped. Will take 2 weeks, but I have other projects to keep me busy...
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • double_DD
          Why does my ISP router hate my "homemade" power supply??
          by double_DD
          It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
          So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
          For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
          07-12-2025, 03:09 AM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
        • Victor Moreira Silva
          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
          by Victor Moreira Silva
          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
          Well, my decice specs are the following:
          Model: Acer Nitro 5 AN517-54-55T5
          CPU: Intel Core i5-11400H
          GPU: NVIDIA GeForce GTX 1650
          Motherboard: GH51G LA-L181P Rev:1c
          The symptom:
          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
          05-26-2025, 10:49 AM
        • feherhollo
          WSON8 NEW Bios Chips READ, ERROR, ETC.
          by feherhollo
          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
          11-26-2023, 09:33 AM
