Flux remover keeps leaving residue
  • Maxxarcade
    • Jul 2006
    • 973
    I'm having trouble with flux remover lately. For some reason, it keeps leaving a white residue, almost powdery texture on whatever board I try to clean. I've tried a couple different methods, using both Chemtronics Flux-Off and regular denatured alcohol. The resulting residue looks like corrosion when it dries, and it's driving me crazy. The boards look better with flux on them than they do with this damn residue
    Is there anything I can do to fix this? It seems to be worse on certain boards than others. I'm trying to clean them up for a finished appearance, so this bothers me.
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Re: Flux remover keeps leaving residue
    I've had problems with that residue, but not all the time. Must be different flux formulations??? I had to use a lot of alcohol and brushing in one direction toward the nearest edge of the board. Still ended up with some here and there.
    As of late, I've been using a water based flux. After soldering, I just grab an old toothbrush and put it under running water....not real hot, but reaaally warm. I've had no problems with residue at all.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • Maxxarcade
      • Jul 2006
      • 973
      The solder I use is Kester 60/40 rosin core, Maybe I need to get some different solvent? I'm thinking of trying the 63/37 solder too.
      • MixMasta
        • Feb 2006
        • 142
        Thats exactly what I use too and I haven't had any problems... though I don't do any repairs near as complicated as you probably do.
        • starfury1
          • May 2006
          • 1256
          Cant really help you with the flux issue, you are using what I would try. apart from possibly metho then alcohol
          I suspect stretch maybe on the money here with a flux formulations? may have been changed.....but I don't know
          60/40 solder was the norm due to it having a small plastic state between liquid and solid
          which I understand was better.
          63/37 has minium plastic state which if memory serves may result in a higher amount dry joints being made. (which is why 60/40 ratio was chosen for electronics work)
          I would have to check this and I will stand to be corrected but like I said,
          thats the story if memory serves me.
          Anyone know if RoHS has resulted in any flux formulation changes off hand?
          cheers
          • starfury1
            • May 2006
            • 1256
            As I said I could be wrong
            on this page
            Tends to support the above about statement about 63/37 solder ,
            see SOLID, PLASTIC and LIQUID
            This page tends not to here
            See "'Solder Types"
            Me I use 60/40 but like all of us soon, will be forced to use RoHS spec
            Sure others here will have good input on the pluses and minuses of both types
            Cheers
            • dungbeetle
              • May 2007
              • 94
              That was some interesting reading on the solder and flux types. Now how do we know if we have 5 core flux??
              Regards,
              db
              • chth96
                Is it good to use chemistronic flux off es835b for flux remover?
                by chth96
                I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                11-17-2023, 07:25 AM
              • acedogblast
                by acedogblast
                11-02-2024, 05:13 PM
              • evilkitty
                Flux causing high resistance short?
                by evilkitty
                Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                Temp is on the left humidity is on the right
                i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                The pin out looking down from the top is (note this is common cathode)...
                07-17-2024, 09:38 AM
                Multifix 425-01 and 450-01 Rework Flux Datasheet
                REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                - No Clean Formulations
                - Low residue
                - Range of activity to deal with different component solderability
                - Halide free
                - Suitable for dispensing
                - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                Both products are supplied in syringes or cartridges for application by dispensing....
                10-07-2024, 06:02 AM
              • chth96
                How can I remove flux with the smallest rubbing?
                by chth96
                I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                Is there any way to remove flux with the smallest rubbing or without any rubbing?
                Any reply would be appreciated.
                11-24-2023, 05:22 PM
