LED lighting batten drivers
  • onextwo
    • Oct 2023
    • 6
    In my workshop I have 12 LED lighting battens and the some of the drivers have failed.
    In side there is 2 aluminium PCB with a 72 LED on each PCB as ‘current' Schematic.
    I am looking the get some constant current led driver to replace them.
    is it there any problem wiring as ‘option 1' Schematic or is it best as ‘option 2' Schematic.
    With option 2 I would have to modify the all PCBs, so a lot more work.
    • 31048
    option2 is going to be less effected by led failures.
    having said that - the original is using 51v to drive 4 leds - 12.5v per led - are they single-chip?
    if they need 12v you need to use a 100v driver
    whats failing anyway?
    better to sort the problem - if these are sealed units it may be overheating so un-casing them would help
    or the caps could be dead from heat
    • redwire
      • Dec 2010
      • 3910
      cross-posted https://www.eevblog.com/forum/projec...batten-drivers
      • onextwo
        • Oct 2023
        • 6
        Hi stj thanks for your help.
        Yes I have got it all wrong. See correct schematic.
        • onextwo
          • Oct 2023
          • 6
          The question I should have asked is:
          What is the better circuit design Schematic 1 or Schematic 2
            • 31048
            1 is best - the panels cant effect each other much
              Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
              This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-06-2024, 08:00 AM
            • japlytic
              DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
              by japlytic
              In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
              Tried (only with keyboard/mouse connected):
              • BIOS + database update
              • Using latest Windows 11 image built with official image creation tool
              • Previous setup version for Windows 11 installer
              • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
              • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
              • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
              06-19-2025, 04:59 PM
            • Topcat
              Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
              by Topcat
              Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
              Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
              09-29-2024, 03:55 PM
            • pavithra
              LC6685 based LED drivers
              by pavithra
              I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
              I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
              Is it possible to get the datasheet of LC6685 IC?
              Also highly appreciate if you could let me know what could go wrong....
              04-16-2024, 02:46 AM
            • kuba2102
              Alienware m15 R4 CPU or CPU drivers issue
              by kuba2102
              Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
              01-04-2023, 09:05 AM
