Voltage mod (need help with picking resistor)
  • daRk_Kon
    • Apr 2007
    • 109
    i want to do both of the mods in this thread (first couple of posts) http://forums.vr-zone.com/showthread.php?t=23332
    is there any place i can find a 10k ohms variable resistor? or should i even use a 10k ohms variable resistor?? or perhaps a different one?
    heres where i got the info for a 10k ohms variable resistor http://forums.vr-zone.com/showthread.php?t=21718&page=2
  • gica69
    Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
    by gica69
    I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
    Resistor shows orange range silver gold and green lines.
    Thanks in adv...
    07-21-2025, 09:49 PM
  • jinu_j
    by jinu_j
    Hi
    05-03-2025, 10:51 PM
  • mikey5791
    by mikey5791
    Hi to all forum members,
    12-26-2024, 04:55 AM
  • waigy
    Variable resistor potentiometer has different reading when mounted on the board
    by waigy
    In my fusion FE-402 car amplifier the gain pot is an RK097G.
    I think it is anyway, the RK097G is the closest I've found to the original with the same pin number and dimensions.
    The differences are my pot is blue and has B203 on it and the shaft is plastic with a small slot at the very end only.
    I measured the resistance and found it went from 0 up to 10k so I ordered a 10k pot.
    I then took the pot out the board and it now measured 22k.
    I tried putting it back in the board and it goes back to 10k.
    Is this normal and if so what pot should I order?
    On this...
    11-12-2024, 04:44 AM
  • artvandalai
    What resistor ohm will work better to repair this waterpik?
    by artvandalai
    The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
    01-05-2025, 04:10 PM
