ceramic disk labeled 102k equals?
  • aortiz
    • Feb 2014
    • 120
    • mexico
    i have this small size ceramic disk with 102k marking on it .
    what is the value of it ?
    in mfd?
    in nfd?
    those are the values that my meter read (fluke 79 series2 multimeter)
    thanks in advance
    Re: ceramic disk labeled 102k equals?
    1000pF, I think.
    It's 10pF * 10^2 or 10pF * 100.
      Yes, that is 1000pF or 0.001uF.
      This type is marking is in pF.
      102: 1,000pF = 0.001uF
      103: 10,000pF = 0.01uF
      104: 100,000pF = 0.1uF
      105: 1,000,000pF = 1.0uf
      See the pattern in the numbering?
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        What tom and bud posted, plus "K" in this context means a +/-10% tolerance (not counting the temperature and voltage coefficients of the ceramic dielectric, which may be far worse than the 10% initial tolerance).
        PeteS in CA
        • aortiz
          • Feb 2014
          • 120
          • mexico
          thank you guys,
          i am just poking around a monitor that turns off when it goes into high resolution 1024x768 or higher.
          • aortiz
            • Feb 2014
            • 120
            • mexico
            thank you
            • Agent24
              I see dead caps
              • Oct 2007
              • 4979
              • New Zealand
              Originally posted by aortiz
              thank you guys,
              Stupid question, but have you verified that it supports resolutions higher than 1024x768?
              Some monitors turn off rather than displaying an "over range" message.
              -David VanHorn
              • welp
                PS5 Disk Tray issues.
                by welp
                I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
                Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
                Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
                So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
                With that knowledge I preceded to check all the fuses for the 12v rail on the main...
                12-19-2024, 02:04 PM
              • DynaxSC
                ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                by DynaxSC
                I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                The behaviour is also really very strange, i.e.:
                • The disk shows always up in BIOS - so it is recognized, so far so good
                • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                02-23-2025, 01:33 PM
              • madura2010
                DAY11AM6E0 hard disk drive and optical disk drive not detected
                by madura2010
                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                i checked the connectivity of ribbon=good communication with hard and motherboard
                changed hard disk and checked=3f0 error persist
                sata power=+5v available
                Then checked data capacitors=all good
                Then checked data lines path connectivity to pch=all good
                reflashed...
                03-12-2023, 09:09 AM
              • chth96
                LG GCC-4521B cannot read any disk
                by chth96
                I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
                But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
                And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
                But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
                02-13-2024, 07:31 AM
              • Eleways
                Apple Macbook A1707 Hard disk
                by Eleways
                Hi
                I've an Apple macbook A1707 with Hdd defect.
                This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
                My question is:
                Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
                Can i replace with a different one (es 500 gb instead of 250 gb)
                This Macbook has T1 security check.
                Thanks and best regards
                Luca
                02-18-2022, 04:23 AM
