Y4 diode identification
+ More Options
Posts
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Please help me identify this zener diode.
    I find it hard to see the datasheet. The diode was found on 14TB 3.5" WD HDD
    I'm looking into having it replaced.
    Pictures attached
  • truclacicr
    • Apr 2019
    • 327
    • australia
    It's a 12V unidirectional TVS diode.
    • Zilicon
      • Nov 2020
      • 142
      • Nigeria
      Please can I have the datasheet?
      And please, how do I source for datasheet of stuff like this?
      S-manual.com was not really helpful
      • truclacicr
        • Apr 2019
        • 327
        • australia
        I haven't been able to find a datasheet. I just know from experience that HDDs have two TVS diodes (5V and 12V) at the power inputs.These can usually be replaced with SMAJ12A/SMAJ5A, SMBJ12A/SMBJ5A or SMCJ12A/SMCJ5A, depending on dimensions.Also be aware that there is often a 4A smt fuse (marked "S") in series with each diode.
        • Zilicon
          • Nov 2020
          • 142
          • Nigeria
          Thanks a lot.
          S-manuals.com seem to lead me astray.
          TVS make more sense than what S-manuals is giving me, especially considering how it was arranged in the circuit.
          How wish there's a reliable website where one can identify these parts easily
          • harp
            • Jun 2022
            • 613
            • Planet Earth
            Maybe this:
            BZX584C15
            https://www.alldatasheet.net/datashe...BZX584C15.html
            You are on it...
            • Zilicon
              • Nov 2020
              • 142
              • Nigeria
              Originally posted by harp
              Maybe this:
              BZX584C15
              You are on it...
              Thank you.
              I saw something related too. All pointed to a zener diodes. Different diodes with different electricl characteristics.
              • truclacicr
                • Apr 2019
                • 327
                • australia
                It can't be a zener. A zener is far too slow, for a start.
                • Zilicon
                  • Nov 2020
                  • 142
                  • Nigeria
                  Exactly.
                  • hobostove
                    Corsair RM1000e - Help identify 5VSB Zener diode
                    by hobostove
                    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                    There's a 22ohm resistor that's melted and open, but it still has the bands.
                    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                    It looks like the diode connects the source and drain of a TNY284...
                    03-27-2025, 02:25 PM
                  • unimatrix93
                    TV backlight zener diode
                    by unimatrix93
                    Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                    So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                    Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                    The led strips has 9 6V leds.
                    02-10-2025, 12:13 PM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    by sam_sam_sam
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
                  • nev1001
                    What zener diode might fix the sound on Maestro Mayhem gaming chair?
                    by nev1001
                    Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                    The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                    It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                    I think an issue could be a zener diode (or capacitor) which has shorted out.
                    The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                    04-17-2025, 05:09 PM
                  • Vincenzo2
                    Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                    by Vincenzo2
                    My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                    Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                    I put some pictures here to show that it is labeled "M7"....
                    09-07-2023, 07:43 PM
