I need some help on identifying this part number.
This topic has been answered.
Answer selected by ambetz12 at 07-10-2024, 03:29 PM.
- Selected Answer
- Selected Answer
by esiniorHi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
I've attached pics of this part
Thanks...4 Photos -
by YanlebIn the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
For an example, look at the attached PDF.
Do you have a way to cross reference the Panasonic part number with the actual part number?
Thanks....07-03-2023, 08:16 PM -
by eng.umair.aDell G series Gaming Laptop
G15 5535
MB: IDO51 LA-M534P Rev 1.0(A00) 2023-02-02
PU9501 is shorted IC is marked as B3FNM but i am unable to find this ic... -
by eng.umair.aI need to identify a burnt ic but cant find any schematic if this board if anyone can post pics of this board of can tell me ic part number it will be of great help....
hi....i need part number for chip...it is writen 2N=7C and next line is C7H.....is this rt8249??....thank you.
Channel: Common Parts Library - Datasheets
- Loading...
