SCM6D diode
    • 31137
    SCM6D diode
    high voltage diode from 1972.
    anybody got a datasheet?
  • DynaxSC
    Extreme High Current & Low Voltage Short Killer ??
    by DynaxSC
    Hi Folks
    I'm looking for a extreme high current short killer solution for a reasonable cost.
    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
    After taking off the socket, the shorts dissappear again.
    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
    10-15-2024, 10:13 AM
  • abajor
    A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
    by abajor
    Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
    PPBUS_3GH diode: measures good .45V
    PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
    The weird so far is
    PP3v3_G3H_RTC_X diode: .104V (WTF?)
    PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
    Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
    Not sure what any of this means...
    03-18-2025, 10:27 PM
  • harp
    high voltage high resistance marking resistor
    by harp
    Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
    08-26-2024, 01:42 PM
  • tvguy12012012120
    by tvguy12012012120
    02-07-2025, 05:13 PM
  • conghuyms
    MSI RX580 Vcore voltage is too high, please help me !!!
    by conghuyms
    I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
    I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
    Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
    What should I do...
    08-02-2025, 11:38 PM
