Build A Tool For Battery Spot Weld Removal with a Geared Servo Controller
    • Jul 2011
    • 6070
    I going to build one of these DIY projects for removing battery tabbing I saw this YouTube video last night and got inspired to make one for myself to make this process easier to do and keep damage to batteries to a minimum and keep stress level down as well
    Here is the video website link
    https://www.youtube.com/watch?v=saKO6Wvg95U&t=0s
    Geared Servo box plus controller
    https://www.ebay.com/itm/28314142446...Bk9SR_iG6pjBYw
    Here is the IKO LWLG7B + 120mm, One LWLG7B Linear Guide Block on a 120mm Rail
    https://www.ebay.com/itm/154801219906
    Here is the servo controller
    3 Modes ESC Servo Tester Electronic Speed Controller Checker Master for RC Car
    • 31301
    use a dremel like everybody else
    • harp
      • Jun 2022
      • 648
      • Planet Earth
      Here is the video website link...
      Geared Servo box plus controller...
      Here is the IKO LWLG7B...
      One LWLG7B Linear Guide Block...
      120mm Rail...
      Here is the servo controller...
      3 Modes ESC Servo Tester Electronic Speed Controller...
      Is there any reason to engage lots of electronics and fancy stuff to obtain just bare mehanical job?
      Design may follow same principes, with materials from scrapyards, but powered by pushing handle of that lever mechanism by hand... I dont get it... it will be even better because it is hand power cant discarge.
        • Jul 2011
        • 6070
        The problem with doing this with a dermal tool is that when you grind the tits off because they are mostly metal the battery cell end rust because they are only lightly nickel plated so this is the reason I have not proceeded very many of the ones that I have is because of this now iIf you put some solder on the tabbing and the battery cell plate then you do not have this issue but it is time consuming unfortunately
          • 31301
          if they rust you need to fix the enviroment they are in or paint them with laquer or something.
            • Jul 2011
            • 6070
            Well I bought of these Gear Servo with the round face plate with no teeth but it has the hole for the arm that I am going to use for this project but I going to design it a little bit differently because first of all I going to have the blade a little bit lower and I going have slide bar on it to make it easier to change the battery size but unfortunately only the seller in China offer the arm plate so I am going to have to wait about a month before I receive this device
            Here is the one that I bought
            https://www.ebay.com/itm/335007738098?var=544228355313
              • Jul 2011
              • 6070
              I thought about what STJ mentioned earlier about using a dermal tool to remove the tits off the battery terminals I might still have to use it on ones that are not completely removed by the tool but there is another reason for building this tool also to open plastic enclosure for switching power supplies and battery pack enclosures that have no screws to take them apart because doing it by hand sometimes is difficult to do at best and yes I have open quite a few of them in the past and if you damage the enclosure it is difficult to re- glue the enclosure back together and looks like crap when this happens there is not much you can do to make it look better but I recently I saw a YouTube video where someone used plastic wire tie strap and a soldering iron and melted it over the seam of the enclosure and then put a piece of aluminum tape over it until it cools down and remove it and it looks like it was just a slightly different than the original design of the enclosure surface but it does not look bad I will have to give this a try and see what kind-a results I get do this
              I also found that Ryobi has black hot glue sticks now I bought a couple of bags of them but I have not used them yet but I will let you know what the results are when I use some
                • Jul 2011
                • 6070
                The issue I have building a mechanical system is that first of all the starting point and stopping point would not be consistent enough for me and would be difficult to achieve with out a lot more time to design it and test it and you still have to make the sharp small blade width so that you do not damage the the heat shrink tubing that is on the battery cell which if does not starts just below the top of battery terminal and stops just before the bottom of the battery terminal then you are more likely to damage the heat shrink tubing but honestly I did not even consider doing mechanically until you mentioned it in your post that is why I did not comment about your post until now because I really thought about it and I appreciate your comment about it
                  • 31301
                  the way i open psu's is to squeeze the case in a vice, it will often crack the seam open
                  • harp
                    • Jun 2022
                    • 648
                    • Planet Earth
                    If you have jobs of large quantity the some machine is necesary, but if you have a couple bateries ocasionaly you can modify flat pliers with grinding away to needed shape and dimension.
                      • Jul 2011
                      • 6070
                      I will have to try this idea when I find a pair of this type of cutters again I have to remember where I saw this type of cutting pliers before
                        • Jul 2011
                        • 6070
                        Well the motor servo finally got here today
                        Now I have to find the time to work on it
                        • TimScrawn
                          MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                          by TimScrawn
                          Hi there,
                          This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                          I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                          06-23-2024, 09:41 AM
                        • Dobrowol
                          Dell Latitude 3520 help with bios build/repair
                          by Dobrowol
                          Hello. Ive got problem with Dell Latitude 3520. After power on, no display and fan goes crazy. Standard job, I exported a clean bios from update via pfs extract.
                          Steps i done and results:
                          I exported a clean bios from update file via pfs extract.
                          1. Build clean bios with clean ME, PMC, PCH in flash image tool.
                          Result: Dead
                          2. Build clean bios with no changes in ME, new PMC, PCH
                          Result: Dead
                          3. Build old bios with clean ME, new PMC, PCH
                          Result: The same
                          09-22-2023, 02:43 AM
                        • Badpatch02
                          Thinkpad X380 Yoga supervisor password removal + Intel ME removal question
                          by Badpatch02
                          Hi all, I'm new here, a few words about myself: CS student, interested in hardware stuff too - tinkering my whole life but with practically no experience when it comes to firmware "hacking".
                          So I have this X380 Yoga with a supervisor password in place and before doing anything stupid I figured I'd rather ask.
                          I plan on using the tool from this thread: https://www.badcaps.net/forum/troubl...password-remov...
                          11-30-2024, 05:22 AM
                          ACER Revo M2-601 Revo Build i3-6100U Specification for Upgrade or Repair
                          This specification for the ACER Revo M2-601 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Revo M2-601 boardview and Revo M2-601 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ACER Revo...
                          09-12-2024, 03:28 PM
