it5570e-128 schematic
  • Rahul Morya
    • 13
    • India
    I need schematic of it5570e-128 SIO chip ic.
    thank you in advance
    • 31159
    find a schematic of a machine that uses it.
    • Rahul Morya
      • 13
      • India
      Have you an idea in which machine this would be present?
      • truclacicr
        • Apr 2019
        • 334
        • australia
        https://www.mikrocontroller.net/atta...tsky_arx15.pdf (page 105)
        https://www.e-weekly.co.uk/download/...dx/esm.pdf?lce (page 61)
        https://download.csdn.net/download/fxw12399/11855766 (datasheet, if you can navigate the BS)
        • Rahul Morya
          • 13
          • India
          Thank you so much dude 😊👍
          • yurbelka67
            • Feb 2018
            • Ukrain
            Thank you !
            • trannhan238
              • Jan 2021
              • 18
              • Việt Nam
              thank you!
              • psjayan80
                • Apr 2016
                • 5
                any one knows IT5571E-128 chip programable or self programed ?
                • kk126
                  • Mar 2021
                  • 18
                  • mexico
                  Were you able to find out if it is programmable or did you change it on the board?
                  • Maxsupri Informatica
                    • Mar 2024
                    • Brazil
                    https://ia800805.us.archive.org/18/i...A_V0.3.1_U.pdf
                      • Mar 2024
                      • Brazil
                      Originally posted by Maxsupri Informatica
                      page 41 and 42 pinouts
                        • Mar 2024
                        • Brazil
                        • NiroPall
                          Schematic need for XT-4015 ver.F (POS machine pc board)
                          by NiroPall
                          Hi, Friends,
                          Recently i ve got a pos machine board and the problem was 3 USB ports out of 5 not working. When a mouse is plugged mouse light is worked, but not detecting.
                          So i changed bios chip from all working machine and then Usb PORTS work for few minutes. So any one of you have same experience with this board. please share your ideas,
                          and schematic if you have,
                          Model - XT-4015 ver F.
                          Thank you.
                          01-10-2024, 12:12 AM
                        • CG2
                          Janome DC3050 Sewing Machine Pedal Resistance
                          by CG2
                          OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                          Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                          04-14-2023, 07:53 AM
                        • TinkerTron
                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                          by TinkerTron
                          Hey everyone,
                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                          Instead, here's what's been bugging me so far:
                          The schematic...
                          03-06-2025, 02:03 PM
                        • Thetechdude
                          MSI Ventus RTX 4080 16G Broadview schematic needed
                          by Thetechdude
                          Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
                          I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
                          Thanks.
                          07-15-2025, 11:15 AM
                        • ianpoultonknights
                          Zenbook Flip 15 UX562AI schematic
                          by ianpoultonknights
                          Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
                          06-26-2025, 02:41 PM
