Has anyone ever used a “controller power path switch IC chip”before and dose it come on a board
    • Jul 2011
    • 6057
    I was watching a video about controller power path switch on YouTube and was wondering if anyone has used one before and if so what was the result from that use
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
    Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
    Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
    ( needs more cam circuits for the machine to work correctly again )
    https://www.ebay.com/itm/275321870186
    To
    3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
    ( not 4 positions but the right amount of cams circuits )
    https://www.ebay.com/itm/274660439950
    I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
    03-18-2023, 05:12 PM
