I once run into some more detailed talk about the glue here on forums but I cannot find it now. ANyone remembers? There were some ideas abotu what the filling is (possibly flour) and information about what the glue is actually from. With notice from manufacturer saying explicitely it should not be used in electronics.
About the yellow glue…
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None -
Re: About the yellow glue…
This is what I have, been dealing with it since the 70's.Attached FilesNever stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Chloroprene, that's it. Thanks! Can I distribute this file?Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Yes.Never stop learning
TY sir!Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
I have pictures somewhere on my computer that I took when I measured the resistance of that tan glue, found in the power supply of a HP DC5000. If I remember correctly, the resistances I got for some of the more burnt samples was in the range of a few 100's of KOhms all the way up to 1 MOhm.Comment
I use high voltage power supply with current limiter (10mA) >100V to see how much current it can conduct, it can conduct quite a bit of current due to voltage breakdown which the meter cannot not put out high enough voltage like the circuit can, especially around the snubber circuits or inverter section.Never stop learning
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by madyoyoHI.
I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming.... -
by nick3092I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
by multimesutHello friends,
A yellow light was flashing on my monitor. It was like it was constantly cutting power. When I opened it up, I saw that the big capacitor in the high voltage line was leaking. I replaced it. When I turned it on for the first time, it had the same problem again. But then, interestingly, it got better. The yellow light was on steady. But the monitor wouldn't turn on. When I examined them with a thermal camera, I saw that the Fli5961-LF reached 50 degrees Celsius and the EM636165TS next to it reached 100 degrees Celsius and was drawing high current on the motherboard....1 Photo-
11-13-2024, 07:00 AM -
by Big PookaHello all,
I just picked up a LG OLED65E6P off of Craigslist (it was practically free). It functions flawlessly in all aspects except it renders yellows as greens. It does so regardless if the source comes through an HDMI port, or streams in through onboard services such as Netflix.
I've factory reset all the color options, cleared the panel noise via the onboard option, and waisted half an hour talking to LG customer service.
Have any of your dealt with this situation?
I understand OLED's are susceptible to burn-in, and looking at the... - Loading...
