The old IC appreciation thread
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    The rack of bins of parts came from an older professor of mine... he also gave me a 1963 Heathkit 1012 scope (AC 1-channel, vaccum tubed) in full working order that he built when he was 18 (if that tells you how old he is)... but that scope is worthy of it's own thread (especially given that it's all I have for a scope). He tells me most of these chips were free ones he got as samples over the years... Many I suspect are somewhat rare.
    If you love gold leads/contacts, keep reading... lots of gold here. And no, I'm not gonna digger gold these things (they're too cool even if I don't have a use for them)
    Anyway, we first have a mectric buttload (14 chips) of Motorola XC8520
    I'm almost certain they're all engineering samples... IIRC they were used in the Apple I and Altair 8800...
    Next, some XC6800B:
    And a MOS 6502:
    A lone 6850:
    Some old RAM IC's:
    Some GE 10 bit DACs:
    (that was almost what I was needing for one of the parts, I ultimately settled on a modern SPI 8-bit)
    Here's some chips so old I can't get a datasheet on them:
    They may be ADC chips but I really don't know. The bin is labled as "CUSD-A/D's" if that's a hint.
    Some old dual op-amps:
    The lower one is another 747.
    some screwy multi-digit 7 segment displays:
    I can't find a pinout anywhere on those... someday I'm thinking of making a watch/clock with one.
    some old single digit 7-segments (most made by HP):
    Old-style packaged LM311:
    Some old 555/556 timers:
    Last, there were all sorts of 4000 series chips... most were plastic or black ceramic... but I found some execptions in the 4011 bin:
    Am I the only person who thinks old chips are cool?
    sigpic
    (Insert witty quote here)
  • mariushm
    • May 2011
    • 3799
    Re: The old IC appreciation thread
    The pinout for those 7 segment displays is super simple.
    They're common anode or common cathode, meaning the segments are joined together for all digits and then you have 5 pins (one for each digit) that either takes current (common anode) or sinks current (common cathode)
    So if you want to display something, you have to go in a loop through each digit and give/sink power through the pin for that digit and sink/send current through the particular segment.
    Easiest way would be to get a couple of AA batteries or around 3v and a 330-1000 ohm resistor and simply try put power through pins from the opposite sides.
    Most such display have maximum reverse voltage of about 5v so use lower voltages to figure out the pinout.
    The single digits are the same.. one cathode/anode and the segments and the dots. The anode or cathode is usually on the corner somewhere.
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      Not at all. Old Motorola stuff and LED displays are awesome!
      There are twisted elaborate ways to build an SMPS with those parts. As in each function per chip. With the 556 and LM311, you're mostly there.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I knew saving these would be worthwhile someday! j/k
        A few more coming when I have time...
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Intel!
          all my really old chips are motorola (minus an AMD dual op-amp?)... no old intel chips.
          sigpic
          • Rangefinder
            • Dec 2010
            • 11
            • Gods country until the Politions got ahold of it...
            Photo 9/13 .The funny Led 7 segment displays look just like the displays that were used by HP on their early calculators. They were also used on other equipment but at this time I can't say which. In the 80s they went over to LCDs. A lot of HP projects excess parts and engineering scrap went into a bin available to schools. A lot of what you show looks as if it came from that bin.
            3
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              Yes, rd, that 747 is a dual uA741-type op-amp, and it was made by AMD. Back in the mid- and late-70s AMD made linear ICs as well as digital.
              Since Mot P/Ns usually had "MC" as a prefix, I wonder if those Mot parts with the "XC" prefix might be pre-production prototypes.
              PeteS in CA
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                just intercepted a bunch here that were given up for recycling.
                worth more for repairing vintage stuff and even ebay fodder for the chip collectors.
                nice to be able to restore something with period correct parts.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  oh yeah... given ebay prices the first picture is worth $196 ($14 a chip)... but since they were gifted, I don't feel good selling them.... however, if somebody here actually needs one of them, I'd send at the cost of shipping or trade.
                  I bet they are... although his professorship didn't start till 5 years ago or so (he was at ITT for a few, he's been at my college, Purdue, for 4 so far... but the last two only part time.)
                  I'm almost certian they are... the first ones are probably (since that's what I got when I googled it), and knowing Bill (the prof), I bet most of the chips in the cabinet are (they're samples he's gotten at the least).
                  EDIT- uh oh! the MOS 6502 is a 1975 chip. Bad right-rotation instruction! Does that make it worth more or worth less?
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    delete this post... (looks at paws, sees no claws)
                    sigpic
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      Intel!
                      http://youtu.be/aEDpqFHTSVM?t=2m14s
                      sorry couldn't help myself
                      Follow the white rabbit.
                      • gg1978
                        • Dec 2004
                        • 431
                        nice old chips The bulk of your motorola chips is from '75, so def worth some money, if not for use.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          I have a huge eprom collection I'm not sure what to do with anymore. The ones I have pictured were the more special one (8748, probably the first all-in-one microcontroller; and the 2708 1KBx8 EPROM). The 2708 isn't very special (1702 predates it, probably more?) but it's in the gold cover/ceramic package that I don't see too much of.
                          The "TO-" round can linear ICs are something though... I think I also have a board with resistor-transistor-logic digital ICs on it, and they're in round cans too...
                          I'll have to look but I'm sure I have some 1960's ICs somewhere IIRC... Those RTL digital ICs may date there. I'll have to also doublecheck the older TTL gates that I have, some may be that old as well.
                          Too bad a lot of my older chips have their markings rubbed off *sigh* I have an ancient 709 op amp whose markings rubbed off so I had to write on it to make sure I remember it's a 709.
                          (and about two or three decades ago I was desperately looking for those 2Kx8 or 8kx8 static RAMs cheaply to build something with... never found any then that I can afford... now all virtually garbage, sigh.)
                          • delaware74b
                            • Apr 2009
                            • 628
                            RD - those HM6116's are Hitachi RAM.
                            Cool finds!
                            Stupidity should be a crime, especially for drivers. I have NO patience for them.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Well, I guess some of these are still in circuit or pulls or junk.
                              F996079 - an ancient 1-of-10 decoder IIRC with open collectors. It's used to drive a neon Nixie tube.
                              MC714G - I forget what logic IC this is, IIRC it was DTL or RTL logic that predates TTL...
                              smtdtl - A cursory Google search says they're DTL ICs in the "old school" surface mount technology.
                              And some more 70s ICs, a (fried) 1978 hex-to-7-seg IC/LED, and some old capacitors. Unfortunately most of my really old capacitors are at my parents' house.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                I have some old stuff too, including germanium transistors and diodes. I have some old chips, well, quite a lot ... probably a dozen Z80's, and some intel and AMD chips too.
                                Muh-soggy-knee
                                • MariSico
                                  • Feb 2018
                                  • 19
                                  I have a couple of F996079, do you know where I can get the datasheet or pin-out for this driver?
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Probably need to reverse engineer it, apparently these are way obsolete when the 7441 became readily available.
                                    It does look like pin 16=VCC, Pin 8=GND, pins 15,14(likely MSB),7,6 are inverted BCD inputs, and the rest of the 10 pins are outputs to the NIXIEs. Can't discern much else without more careful analysis...
                                    • R_J
                                      • Jun 2012
                                      • 9551
                                      Is this of any help, the us3838201 file shows a diagram with the cul9960 ic's pinout
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Yeah looks like z4 is the target chip on page 4, looks like 4.5V is sufficient to power it? Still no clear idea which is MSB/LSB except assumptions that it's in bit order of some sort. Pin 14 from what I can tell is indeed MSB, and pin 6 is LSB..
                                        1 !O1 16 +4v5
                                        2 !O3 15 !In2
                                        3 !O5 14 !In3
                                        4 !O7 13 !O2
                                        5 !O9 12 !O4
                                        6 !In0 11 !O6
                                        7 !In1 10 !O8
                                        8 GND 9 !O0 (note, assuming pin 4 is actually !O7 due to it printed twice)
                                        Looks like there's a bit of order to the madness?
                                        Might have to rip them out of the board, or perhaps try to get the board that I have nixie tubes on with the F/CµL 996079's up and running once more...
                                        This board I have is from some qualitative analysis equipment someone parted, its display is X.XX x10^-X though apparently it can't get to 10^-8 or smaller...
                                        • ugamazing
                                          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
                                          by ugamazing
                                          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
                                          08-31-2022, 07:34 AM
                                        • feherhollo
                                          WSON8 NEW Bios Chips READ, ERROR, ETC.
                                          by feherhollo
                                          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
                                          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
                                          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
                                          11-26-2023, 09:33 AM
                                        • Prott
                                          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
                                          by Prott
                                          Hello dear badcappers!
                                          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
                                          Backstory:
                                          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
                                          If there is a way to narrow down which memory module is faulty it would make my life much...
                                          06-03-2024, 12:05 PM
                                        • LukeDavis
                                          Is there a list of known dodgy ATI Radeon chips?
                                          by LukeDavis
                                          Hello again! (People are likely going to get tired of seeing posts from me lol)
                                          I'd like to try and compile a list of known bad AMD/ATI Chipsets and graphics processors.
                                          While I do not possess the knowledge of some of the brilliant minds on this forum, I can at least mention a few chips I've encountered as being troublesome.
                                          1. ATI 216-0752001 (RS880M/RX280M) found inside 2 HP laptops, one I've since deemed screwed, and swapped the board to an intel one, the other HP seems to be less hateful and runs fine.
                                          2. ATI Mobility Radeon X1600 and the...
                                          02-16-2024, 04:34 PM
                                        • piernov
                                          NVidia bumpgate
                                          by piernov
                                          Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                                          Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                                          May complete this post at a later date with more details.
                                          Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                                          03-27-2021, 10:34 AM
