MOSFET Tester
  • speedypro
    • Feb 2013
    • 561
    MOSFET Tester
    Can someone recommend a good mosfet tester? So good that I do not need to remove the transistor off the circuit board for testing
    Thanks!
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: MOSFET Tester
    I am looking too for one windows XP operating system repair software which is will not have to run it so to work.
    Any suggestions ?
    • mockingbird
      • Dec 2008
      • 5484
      Re: MOSFET Tester
      MOFSET testers are not completely reliable from what I have gathered because the only real way to test a transistor is to actually apply its full load to see if it can handle it, and handle it without overheating...
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        Re: MOSFET Tester
        MOSFET is not an transistor its more complicate than that.
        You can measure a shorted one with one DMM, but when you need to do matching for having many in pairs its impossible.
        All that you can do is getting genuine and branded stuff and you hope for the best.
        • Ltank
          • Jun 2013
          • 776
          Re: MOSFET Tester
          I use a Sencore TF 46 Supper Cricket. It was about 600 when I bought it new along time ago.
          Sadly Sencore does not make electronics test equipment any longer. Their stuff was expensive but very well made. Still about the same price used.
          • u271D
            • Sep 2013
            • 59
            • Ukraine
            Re: MOSFET Tester
            check out this youtube vid; it show how to test for some issues with MOSFET while in circuit.
            http://www.youtube.com/watch?v=qG60rPmSqxc
            • severach
              • Aug 2007
              • 1055
              Re: MOSFET Tester
              Atlas DCA - Semiconductor Analyser - Model DCA55
              That gives you go/no-go. The next step up is a curve tracer. If that's not enough get a Semiconductor Parameter Analyzer. That what the pros use to generate all those nifty charts and parameter lists.
              sig files are for morons
              • u271D
                • Sep 2013
                • 59
                • Ukraine
                Re: MOSFET Tester
                He's asking for an In-Circuit tester the Atlas DCA and DCA Pro are for testing out of Circuit.
                • speedypro
                  • Feb 2013
                  • 561
                  Re: MOSFET Tester
                  Thanks for stating that Need an in-circuit tester. Hate to desolder only to find the part is ok.
                  • barry wilkins
                    • Aug 2009
                    • 172
                    Re: MOSFET Tester
                    I tried to test a power MOSFET using info I found on the internet ,but the idea did not work. As I was making an inverter had to use that to test them . One of the IRF BC30,s I was using did not work , none of the usual static tests showed anything wrong with it.
                    Barry Wilkins
                    • u271D
                      • Sep 2013
                      • 59
                      • Ukraine
                      Re: MOSFET Tester
                      Barry Wilkins
                      In the video I linked to earlier the guy is testing MOSFET's that are still installed in an inverter. It might be the things you already tried or not :-)
                      • senz_90
                        • Aug 2013
                        • 328
                        • Indonesia
                        Re: MOSFET Tester
                        i have read before on googling about test mosfet with finger touch. it is good method when i try it out of circuit, but i have same symptom about in circuits mosfet tester regardless i have reading when mosfet fails, it is most shorted between gate and source pin, and this forum ever discuss it too at "2 second to black" lcd tv troubleshoot. it says when resistance below 30 ohms, it is suspect to defective.. you can read the full description how to connect probes to the mosfet pins on that thread. it is a good investment if we can get a reliable in circuit mosfet tester?
                        "There is no shortcut to be successful. No pain, no gain."
                        Best Regards
                        Rudi
                        Thank You
                        • Nooy
                          VGA MOSfet permanently shorted and loss of MOSfet pad
                          by Nooy
                          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                          02-14-2024, 02:26 AM
                          Here is a good USB C tester that actually works first time you connect it to a device
                          Here is where you can find one
                          https://www.ebay.com/itm/11450939852...53.m2749.l2649
                          I am not getting paid for this recommendation nor was it a free item from the seller
                          I have bought several USB A/C type testers are not worth a crap for USB C you have to connect it several times to a USB C device before it recognizes the device to me this is worthless
                          The only downside of this tester is that it does not tell you what protocol you are accessing but this to me is not a very big deal because I would...
                          06-06-2022, 05:42 PM
                        • AppleLover123
                          Asus X712EA 3 volts after the first mosfet
                          by AppleLover123
                          Hey guys,
                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                          Now i thought something...
                          12-15-2024, 07:49 AM
                        • MicroSMD Lab
                          by MicroSMD Lab
                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                          01-10-2024, 06:36 AM
                        • madan1
                          555 based power supply getting too hot
                          by madan1
                          Good day.
                          I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                          The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                          After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                          When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                          06-23-2025, 04:38 PM
