choke \ mains filter
  • stewart
    • Jan 2007
    ok guys, im trying to put together a mains filter. well 2 actualy, one for pc, the other for entertainment system.
    got myself some x and y caps, and a few mov's. question is, related to winding a choke.
    is there an optimum number of turns?
    is it better to have both coils on one ferrite ring, or seperate rings?
    (if im remember here, one is wound clockwise, the other counterclockwise)
    ta
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: choke \ mains filter
    Without tens of thousands of $$ worth of equipment, "optimum" just doesn't fit your circumstance. Your more in a anything will do something situation. That isn't a put down since the same would apply to me.
    There are two kinds of inductors commonly used in a filter. The differential mode inductor has a single winding and typically uses a powdered iron toroid (donut-shaped) core. Micrometals type 26 or 52 material would be good choices. Pick a decent size and put lots of turns on it. AWG #20 should suffice for 4A or less; AWG #18 for 8A or less.
    The common mode inductor has two windings and usually uses a 5000 or 10000 permeability ferrite core (Magnetics Inc., Fair-Rite, Ferroxcube, MMG and TDK are good brands). You need to use insulated wire (not just the varnish on magnet wire) or use polyester or similar tape to insulate the core to avoid shorts to and through the core. The two windings should be done on opposite sides of the core; safety agency regs, , require 8mm spacing between the wires if they are not insulated (e.g. magnet wire, where the varnish is not considered to be insulation) or three layers of insulating materials between the wires. The starts of each winding should enter the core from the same side when you do the winding, and the starts should both be either the input or the output side in your filter circuit. Each winding should be the same number of turns.
    If you aren't scared out of your mind by the above and are still awake, , I'd suggest finding a couple of dead P/Ss and using their inductors. Realistically, finding and obtaining the toroid cores may be rather difficult.
    PeteS in CA
    • arneson
      • Sep 2005
      • 1267
      I've read a lot of good online DIY power filter projects.
      The toroids are coffee can size,two three or four of them.
      Sorry I no longer have the links.
      I've been using the Pure AV units off Ebay, get them blown for almost nothing.
      Jim
      • PeteS in CA
        • Aug 2005
        • 3581
        Digi-Key has power entry modules and filters-in-a-can here. Corcom is a good brand; haven't heard of the other company. Digi-Key also sells ferrite toroids made by D. M. Steward. I think the ones at the top of the page should be generally suitable, thought the catalog doesn't give the permeability.
        PeteS in CA
        • chopduel
          Bad mains power causing TV malfunctions?
          by chopduel
          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
          • TV would randomly turn off then back on.
          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
          12-29-2024, 03:20 AM
        • cheese007
          Input Filter Filling: How to Choose Components?
          by cheese007
          Recently acquired one of those silly Logisys acrylic power supplies and lucked into getting one of the "better" ones (most of an input filter, bridge rectifier instead of 4 diode treatment, OK-sized heatsinks, etc.) and wanted to fill out what I can on the board + get some decent caps on there (especially the primary side since I highly doubt the ones in there are actually 1000uf). My questions are:
          1. How do I know what components to install re: the input filter? It seem to be missing an X cap, a resistor, and a Y cap.
          2. Where can I find a good heatsink for the bridge...
          12-06-2023, 09:59 AM
        • PennyLane
          Trying to locate a capacitor for a Skytec Crossover filter
          by PennyLane
          Hi
          I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
          02-19-2025, 06:47 AM
        • J_T
          Operating frequency for motherboard common mode inductor/filter
          by J_T
          I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
          The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
          Sorry, I am not experienced hence a basic question.
          01-04-2025, 05:54 AM
        • FZG
          Sony BVM1410PM (CRT Monitor) - Coil Choke Replacement
          by FZG
          Hello there, helpful forum people!
          I am in the process of fixing an old (ca. 1990) Sony BVM1410PM CRT monitor and need some help. The PSU board of this monitor had failed and I had to replace quite a few capacitors and other parts but now - with my limited knowledge - I ran into a wall.
          On the board there is a coil choke that has failed (tested with inductance meter) and I don´t know what to replace it with. According to the device´s service manual the part in question is a "Coil, Choke 525 uH (Sony P/N: 1-459-643-11)".
          The original part...
          05-10-2023, 11:54 AM
