Burnt out reg? on WHR-HP-54G (buffalo)
  • m_elias
    • Jan 2007
    • 5
    Let me know if this thread doesn't below here. I just so happened that the inverter I was using in my car has a 12V DC jack on it that fits into the WHR-HP-54G's 5V DC power plug. I plugged it in, left and returned 2.5 hrs later, started my car and saw some magic smoke!! I'm hoping only the reg (or diode?) needs replacing or bypassing, anyone know if this might be the case? I took pictures and tried attaching them. I have no problem warming up the solder gun to replace it but I'd like to know what exactly that chip does. The only labeling left on it is 'E33' and I think something starting with the letter 'B'. There is another on the back side of the board, same physical specs, it has 'E45' and 'BEH' on it.
  • 999999999
    • Sep 2006
    • 774
    Re: Burnt out reg? on WHR-HP-54G (buffalo)
    Since you haven't had any responses I'll venture a guess. It appears to be a linear, LDO regulator. I am "guessing" it is a 3.3V, opposed to 4.5V for the other one you saw on the back of the board. I'm not entirely basing that on the "33" in E33, also there has to be somewhere generating the 3.3V used by the memory chips on the back (at the least, I don't know what the other chips require but if you really wanted to know you could track down their respective datasheets).
    Most likely it just overheated since it can't shed that much heat from a 12V input. I mean there is a fair chance nothing else is damaged that is directly related, but what 12V in might do to other not-so-related parts of the router, I don't know. I'd think it worth a try to repair it if you happen upon a chance to get ahold of an extra LDO regulator, even if it didn't fit the PCB and had to have a heatsink and epoxy elevating it off the board then air-wired to it, just so long as it has a modest 'sink (probably even a penny epoxied on would suffice as a 'sink if you keep it at 5V input from now on).
    I think the "BEH" (or whatever your broken chip had instead) is just a lot #, inconsequential. I also say it's inconsequential because I used to have one of those routers and have a scanned picture of it. Unfortunately I can't make out anything at all of the markings on the corresponding chip to your failed one, but the E45 chip I can read and it's E45 BEY on mine instead of BEH.
    I don't know how you made out with this repair but if this project is on hold and it would help, next time I visit the friend I sold this router to, I could pop it open and take a meter reading on the output voltage (which as mentioned above, I "guess" it to be 3.3V).
    • m_elias
      • Jan 2007
      • 5
      Thanks for the info and suggestions. I have left this project alone for a while now. I should be receiving my new WHR-HP-54G shortly and compare with. Then I should be able to figure out what the chip was doing and possible replace it with an equivalent. Much appreciated!
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
      • Pinky Deepak
        Vizio M60-C3 Left Edge problem
        by Pinky Deepak
        I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
        Here's a video of both the issues: https://youtu.be/hMqc760nB3o
        09-27-2024, 05:11 PM
      • Rozp
        70LE660U dark cloud or black screen with sound.
        by Rozp
        Hello Everyone,
        This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
        I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
        08-29-2023, 05:25 PM
      • dicky96
        Zotac GTX 260 burnt component - can anyone identify?
        by dicky96
        Hi guys
        This Zotac GTX 260 had a high side MOFET on one Vcore VRM phase short circuit Drain to Gate (Not short Drain to Source)
        This has burnt out the drive IC L3E (ADP3110A) and also an SOT-23 device very close to the driver IC. According to the PCB markings 'Dxxx' this is likely to be a diode.
        Basically the VRM has 4 phases, two powered from one 6 way connector and two powered from the other 6 way
        I would assume each pair of phases are basically identical, the burnt out phase has SOT-23 devices WW1 plus the burnt one.
        The good phase...
        12-01-2021, 01:02 PM
      • armoured_smiler
        Panasonic Tx-40cx400b top left half screen not displaying correct
        by armoured_smiler
        Trying to work out if this is TFT problem or TCon issue.
        The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
        Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
        04-08-2024, 03:40 PM
