mosfet or transistor?
  • MarkM
    • Aug 2013
    • 23
    Hi guys,
    I'm wondering if this is a mosfet or transistor, and the proper way to test it.
    Thanks,
    Mark
  • capkid
    • Oct 2010
    • 1339
    Re: mosfet or transistor?
    That's a diode. Perform these testing procedures in diode mode on your meter (pins numbered from left to right). You may have to remove the diode from the board if the readings are funky.
    Test 1:
    Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V
    Pin 1 - Neg lead, Pin 2 (or the tab) - Pos lead. Expected Result: Open or "OL"
    Test 2:
    Pin 2 (or the tab) - Pos lead, Pin 3 - Neg lead. Expected Result: Open or "OL"
    Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around 0.5V
    LG Plasma Mal-Discharge Correction Service
      That is Dual diode with common Cathode (the Cathode of bothe Diodes are tied together) in the middle big tab, the other two pins are the Anode, in this case, they are also tied together by the the circuit traces. So you can just treat and test this as one SINGLE diode.
      • MarkM
        • Aug 2013
        • 23
        Thanks capkid,
        Here's my results of my test, there are two of these diodes on the board..
        Test 1: doide1
        Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V .046
        Pin 1 - Neg lead, Pin 2 (or the tab) - Pos lead. Expected Result: Open or "OL" .OL
        Test 2:
        Pin 2 (or the tab) - Pos lead, Pin 3 - Neg lead. Expected Result: Open or "OL" 0.000
        Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around 0.5V 0.000
        Test 1: diode2
        Pin 1 - Pos lead, Pin 2 (or the tab) - Neg lead. Expected Result: Reading of around 0.5V .392
        Test 2:
        Pin 2 (or the tab) - Neg lead, Pin 3 - Pos lead. Expected Result: Reading of around .392
        I removed diode 1 from the board to double check and getting the same reading. I take it this diode is bad.
        I just took some new readings and I no longer have continuity to ground with the -VY resistor, and also the rings on the ipm as in this thread https://www.badcaps.net/forum/showthread.php?t=30592 . Wonder if this diode caused the ipm to go bad or vs versa. Should I look further for a cause to what blew out the diode?
        Mark
        • capkid
          • Oct 2010
          • 1339
          According to your testing, both diodes look bad. Did you remove diode #2 from the board to check it?
          There's some info here in the description of Coppell's eBay listing:
          http://www.ebay.com/itm/20LC30-DIODE...-/160645198095
          • MarkM
            • Aug 2013
            • 23
            sorry capkid,
            for diode 2
            where i have
            it is
            reading is OL
            would you still consider this diode bad? (since I'm getting .392)
            • capkid
              • Oct 2010
              • 1339
              Your second diode appears to be fine.
              • MarkM
                • Aug 2013
                • 23
                Thanks, I went ahead and ordered the diode (and one spare )
                Please correct me if I'm wrong.. Voltage flows into the anodes and out of the cathode and blocks it from flowing back(like a check valve)? The two anode spots on the board have continuity to ground. Could something else be bad as well, that trace to the anode spots causing it to ground? Or does it sound right to have anodes as ground?
                • cashkennedy
                  • Aug 2011
                  • 668
                  Are both sides continuous to ground? Is the resistance to ground steady and under 5 ohms? If the resitance fluctuates up might indicate you're actually charging a capacitor that is bridging the anode to ground.
                  It's possible that the cathode of the bad diode is ground, and its "shorting" the anode side by being a faulty diode that's allowing reverse flow that is basically grounding out the anode side.
                  Fixed so far 12 lcd's , 1 plasmas, 5 monitors, 0 dlp's (plan to keep the dlps at 0). and 3 atx power supplies, and 2 motherboards.
                    "The two anode spots on the board have continuity to ground". That depends on how this diode is being used, if the Anode is connected to one wire of the transformer winding, and the other end of the transformer winding is connected to ground which is typical for half wave rectifying circuit, then you will see very low Ohms reading due to low transformer's winding resistance.
                    We need to see bigger pictures of this board to see how this Diode being used.
                    I see you mention Diode 1 and Diode 2, are they the same as shown in the picture?
                      Voltage doesn't "flow"... voltage is sort of like water pressure, and current is sort of like water flow rate. A diode in this case is similar to a valve which only lets water flow in one direction... but it's the "flow rate" it's blocking, not the "pressure" (current not voltage.)
                      • MarkM
                        • Aug 2013
                        • 23
                        Hey guys,
                        cashkennedy,
                        Both sides of the anodes traces are continuous to ground. Ohm reading 000.0
                        The diode is off the board
                        budm,
                        I attached two images, one marked up and one not. Yup diode1 and diode2 are the same shown in the picture.
                        I'm just trying to rule out there's not any other problems before I install the new diode and ipm
                        thanks guys
                          The Anode of that D21 (both pins) are connected to the Ground plane, you can see the GND label on the PCB. It looks like it is for Buck regulator switching power supply. Cannot see D11 traces, but it may be the same for another buck regulator.
                          • MarkM
                            • Aug 2013
                            • 23
                            Thanks budm,
                            Just so I understand, where is the ground label on the board? Is it the dark green mask?
                              Gnd
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4950
                                • New Zealand
                                For the record, a MOSFET *is* a transistor: Metal Oxide Semiconductor Field Effect Transistor...
                                -David VanHorn
                                • dj8452000
                                  How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                  by dj8452000
                                  I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                  02-18-2025, 08:28 AM
                                • InsertCoin
                                  Relay Satronic MMI 810.1 bad diode & Transistor
                                  by InsertCoin
                                  Hello and happy new year ,
                                  my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
                                  There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
                                  The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
                                  I have made a diagram of the PCB and some measurements along some...
                                  01-16-2024, 05:47 AM
                                • Jane
                                  How do you test MOSFET in laptops ?
                                  by Jane
                                  I tried to use this method:
                                  Testing an N-channel MOSFET:
                                  Step 1: Discharge the Gate (turn off the MOSFET)
                                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                  Step 2: Charge the Gate (turn on the MOSFET)
                                  Now, place the red probe on the Gate (G) and the black probe on the
                                  09-27-2024, 03:31 AM
                                • Nooy
                                  VGA MOSfet permanently shorted and loss of MOSfet pad
                                  by Nooy
                                  Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                  I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                  02-14-2024, 02:26 AM
                                • AppleLover123
                                  Asus X712EA 3 volts after the first mosfet
                                  by AppleLover123
                                  Hey guys,
                                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                  Now i thought something...
                                  12-15-2024, 07:49 AM
