need help building a 6 volt turn signal circuit
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Now, this may seem fairly specialized, but I'm hoping that you intelligent folks here can help me out. I need to build a turn signal circuit for my 1966 Yamaha motorcycle. It did not have turn signals from the factory, and I would like to add some even though not required. I'd prefer to be as safe as possible on the road...
    So, I've been looking around, and haven't been able to find ready-built flasher kits that are 6 volt. I have no idea how to build one, but I do know that typical signal circuits only use one flasher device. I have no idea how it outputs discreetly to the left or right signals, though!
    Can anyone help me out? Thanks,
    dood
    Ludicrous gibs!
  • gonzo0815
    • Feb 2006
    • 1600
    Re: need help building a 6 volt turn signal circuit
    This is a product manual for a DIY kit. The language i German, but the circuit should be understandable for you.
    • reessi
      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
      by reessi
      Hello:
      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
      I started on the ACER:
      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
      10-29-2024, 11:31 AM
    • AstutePauciloquent
      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
      by AstutePauciloquent
      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
      11-23-2023, 11:02 PM
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • benspawn02
      Anthem MRX500 - no sound. R2A15218FP issue??
      by benspawn02
      Dear Electronics Experts:
      I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
      08-12-2023, 04:46 AM
      1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
      by sam_sam_sam
      I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
      This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
      12-29-2024, 07:18 AM
