Connecting ground from different power supplies...
  • Knight
    • Jun 2006
    • 19
    Hi!
    This is probably a dumb question but is it ok to connect together grounds from two different power supplies?
    I've seen some schematics where they seem to do that but I'm not quite sure if I'm reading them correctly
    Assuming this is ok, would it be ok to do the same with a battery and a power supply (I tend to think that it would NOT be ok...)?
    Thank you very much for your help!
    Nick
  • ifrythings
    • Apr 2006
    • 19
    Re: Connecting ground from different power supplies...
    If your planning on using 2 power supplies in your computer(one for board and other for drives) it is ok to connect grounds.
    Also, the cases of the power supplies are connected to ground internally, so if you mount both of them in a chassie you don't need to connect the 2 ground wires as the case is doing it for you.
    If you wanted to hook a battery up to a power supply, DON'T, there's too many different problem assosiated with it.
    • Knight
      • Jun 2006
      • 19
      Hi!
      Thank you for your answer!
      What triggered my question are devices connected to the serial/parallel/usb port of a computer... They don't all use the current provided by the pc and frequently have their own power supplies (modem, printer, etc...).
      I think that my confusion comes from the fact that for AC the rules are not exactly the same...
      Have a nide day & happy holidays!
      Nick
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • mkdj
        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
        by mkdj
        Dear all,
        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
        Both N-Channel Mosfets: nothing odd
        P-Channel MOSFET number 1:
        source - drain : 117 kOhm
        source - gate: 96 Ohm
        gate - drain: 117 kOhm
        P-Channel MOSFET...
        08-20-2025, 06:08 AM
      • iMic
        Vintage AT Power Supplies - Selecting Capacitors
        by iMic
        Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
        The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
        02-19-2023, 06:45 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
