Neutral Wire Facts and Mythology
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    By American Power Conversion Corp.
    Power Management DesignLine
    (10/28/2004 11:16 AM EST)
    This article discusses many common misunderstandings about the function of the neutral wire and its relation to power problems. The subjects of dedicated lines, phase reversal, isolation transformers, and grounding are addressed. Various myths are described and criticized.
    In the normal three wire single phase power system found in most offices, the "Neutral" wire is one of the three connections at the wall outlet. Some semi-technical articles and advertising literature for power protection products attribute "special" properties to this wire.
    PeteS in CA
  • wnlewis
    New wire for my RDE3340 Whirlpool electric range
    by wnlewis
    OK. I got the rocker switch figured out thanks to the good advice on this forum.
    Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
    This is a Whirlpool RDE3340 electric range.
    The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
    Where may I find parts...
    01-08-2025, 11:21 PM
  • emeskay
    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
    by emeskay
    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
    08-06-2024, 07:13 AM
  • technicalspecialist
    Vintage fan repair, copper wire question
    by technicalspecialist
    I currently have a customer's vintage fan on the work bench to repair.
    It uses an induction motor with 4 poles. One of the poles is open.
    I couldn't find the break so i cut off the original wire.
    I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
    I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
    The enamelled copper...
    03-16-2023, 12:54 PM
    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
    by sam_sam_sam
    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
    12-16-2023, 08:39 PM
  • kalemaroni
    Dell DC Brown wire
    by kalemaroni
    There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
    08-26-2025, 10:10 AM
