I just want to ensure I am doing things ok here - so I apologize if these questions seem infantile..
Please let me know if I'm missing anything majour....
I especially want to know if I'm failing to take any safety precautions here (e.g. do I need to "discharge" anything before opening up the PSU?)
My current procedure for replacing cap's in a PSU:
1. Unplug and remove the PSU
2. Lay the PSU down on a tray for soldering work
3. Wear grounding strap on my wrist
4. Open up the PSU
5. Desolder capacitors
6. Clean soldering areas with a little 90% Isopropyal alcohol and use small-gauge needles to make sure holes are clean (e.g. 27G/30G)
7. Re-solder new capacitors
8. Close the PSU
9. Replug the PSU (not installed in computer)
10. Attach a couple of 120mm/80mm fans via molex connectors (should have a load on the PSU, right?)
11. Jump the PSU with a small wire to the Green(Power on) line and a black ground line on the MB ATX connector
12. Verify stable +3.3v, +5v, and +12v lines on the PSU
13. Remove jumper to power off PSU and reinstall in computer.
Done.
Does that sound reasonable?
4. Open up the PSU
8. Close the PSU
Done.
