Blackberry Lcd datasheet
  • opamp
    • Dec 2012
    • 160
    • united states
    I'm starting a new AVR project that requires an lcd. Does any body know where i can find information on an lcd from a blackberry??. I need the pinouts for the flex cable. The part number is lcd-11059-005.
  • electomech-fixer
    First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
    by electomech-fixer
    I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
    I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
    Yesterday, 01:42 AM
  • SoulFreeze
    Help finding datasheet for component marked G34662
    by SoulFreeze
    Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
    Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
    Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
    05-01-2025, 03:56 AM
  • Rainbow_Chameleon
    Searching Datasheet for AM113 IC by O2MICRO
    by Rainbow_Chameleon
    I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
    Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
    If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
    On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
    So if anyone has a datasheet or at least...
    01-23-2025, 12:03 PM
  • evgental
    HP prodesk 400/600 G6 mini schematic/datasheet
    by evgental
    Hey everyone,
    I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
    Thanks a lot!
    08-04-2025, 04:58 PM
  • double_DD
    Component identification and/or datasheet, please
    by double_DD
    Hi all
    I have Synology DS115j that I'm trying to repair.
    I've found a short between G and S on Q13, but it's not on mosfet (when I unsolder it). So I suppose problem might be on mosfet driver - I believe U10 is the driver for 2 surrounding mosfets.
    However, I'm not sure exactly what U10 is, so I cannot find the datasheet. (might be uPI semiconductors, but I cannot find anything on their page)
    Any help is welcome, thanks!...
    07-31-2025, 07:48 AM
