Capacitors
  • TorqueRanger
    • Nov 2012
    • 21
    Capacitors
    I am rebuilding one of my boards and there are really small caps of 10uf -25v/22uf -25 ... I was checking them out today and noticed that alot of them had rusty color residue under each of them and let me guess I have to replace them too because they are leaking ??? If this true them I will be buying over 100 Capacitors for a single t.v.....
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Capacitors
    If they are leaking then yes. Could you post some pictures? Those caps are really cheap. With the price break on Digi-Key 100 of those sized caps is under $10 before shipping. Time consuming...yes. Expensive? no
      Re: Capacitors
      Did the board get exposed to a lot of moisture and salty air?
      • TorqueRanger
        • Nov 2012
        • 21
        Re: Capacitors
        Sorry about pics but it's the only camera I have right now
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Re: Capacitors
          Can you get some more clear pictures? Is there a macro mode?
          • 999999999
            • Sep 2006
            • 774
            Re: Capacitors
            Is it under every single one of them? If so, it could just be grime deposits. See if there is a similar brown residue on or under anything else that has no electrolyte to leak out.
            • TorqueRanger
              • Nov 2012
              • 21
              Re: Capacitors
              Sorry about the wait...
              • 999999999
                • Sep 2006
                • 774
                Re: Capacitors
                I can't tell from the pics, is this looking more like brown gunk with dust in it, which probably isn't electrolyte, or more of a crusty lighter colored substance? From what I can see I'd leave the caps in, it's unusual to see ALL of them leaking unless they were all in parallel or complimentary portions of a PSU subcircuit which wouldn't usually use small caps like those.
                What was the initial problem with the TV?
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Re: Capacitors
                  They might be leaking, or it might just be leftover flux.
                  BTW, 'Decon' caps are crap...
                  Muh-soggy-knee
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                  • Cama
                    Solar Inverter - SMH-II - 2 missing capacitors
                    by Cama
                    I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                    My model is : EASUN SMH-II 7 KW
                    Mother Board : P/N 18947-002401250250
                    Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                    Thank you...
                    09-12-2025, 02:50 AM
                  • ctroxtell
                    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                    by ctroxtell
                    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                    01-03-2025, 08:57 PM
