Volume too sensitive on my Spider IV Guitar Amp
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys,
    I have a Spider IV Guitar Amp 75W that has basically no sound between 0 and 1.5 on the main volume knob (which goes up to maximum 10), then once it goes above 2 the volume is waaaaay too loud... I end up spending ages trying to tinker between about 1.8 and 2 to try and find the level I require... Realistically I would never need the sound higher that 2.5 on the amp settings...
    I'm thinking of introducing a similar value pot in series with the current volume pot as a sort of overall amp master volume, adjust this pot to the resistance value where the main volume knob gives me the range of sound volumes that I require between 1 and 10 on the main volume pot.. Is there any problems I should look out for... ?
    (Also when I find that resistance value that gives me the range of volumes that I am looking for, I intend to just solder in a resistor in place of the second pot so the value cant be changed by accident)
    All opinions appreciated.. thanks..
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Volume too sensitive on my Spider IV Guitar Amp
    does the guitar not have a volume control on it? cause it should not be that sensitive !
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Nah T.J., it's nothing to do with the volume on the guitar... I guess I should have a bought the 30W version of the amp, but I just need to work with what I got now... No money :-(
      • t.j.
        • Apr 2010
        • 383
        • canada
        does not the drive control the input from the guitar? put a couch cushion in front of it! lol... jk... there has to be a way to adjust it to do what ya want with out hard modding it!
        • smason
          • 1652
          You have it on "insane"
          Are you talking about the master volume?
          • JonathanAnon
            • Jul 2012
            • 457
            • Ireland
            Yeah it's the master volume switch..
            • smason
              • 1652
              I wonder if it's just dirty. I can't imagine Line 6 designing it that badly.
              My Marshall 8240 needs a serious pot cleaning the master crackles and goes from quiet to blow the doors off. I rarely use it, so I've been procrastinating.
              • 999999999
                • Sep 2006
                • 774
                Yes you could add a resistor, but to replicate the Pot setting you need two resistors to act as a voltage divider. On the second pot you adjusted you would measure between the wiper and input for a resistor between signal input and the (main pot, or if placed after the main pot then between it and amp input) and between the wiper and ground for a 2nd resistor you place between signal and ground.
                I know nothing about this amp, BUT there may be another solution that leaves you with higher SNR, to instead reduce the gain of the amp circuit. Whether that is easy or hard depends on how it is designed, if it uses an IC power amp chip it may be pretty easy. It would sound "better" from a purist audio point of view, but I'm not sure if this matters on a guitar amp as much.
                • JonathanAnon
                  • Jul 2012
                  • 457
                  • Ireland
                  I was working this out in my head, and like what you are saying the only way it would have worked practically would to have replaced (say) a 500k volume pot with two 250K pots... If I'd just added another 250K pot in series with the existing pot, I would have shifted the 0 settings up to about 3 or 4 (I think)....
                  Anyway, I opened it up today... to make a start on my alterations... however, the pot is soldered in to a PCB, a small PCB.... It's too high risk, and there IS NO ROOM to introduce another component... This forces me back to looking at software solution... :-(
                  Hey just as a theoretical suggestion here (and not something that I would ever intend on doing), if I put a 4 ohm resistor in series with the output speaker it should drop half the voltage across this, but I'm assuming no such resistor could possibly exist that could dissipate that amount of power as heat?
                    Can you verify if one end of the pot if you look from the front, the left terminal should be connected to ground if it is setup as volume control not Gain control. If one end is grounded, then use the Ohm meter between Ground and the center viper pin and see if the resistance vary when you adjust between FCW (Full Clockwise) and FCCW (Full Counter Clockwise).
                    • spleenharvester
                      • Mar 2010
                      • 921
                      Are you just using it for bedroom-level volumes mate? If so it might just be you bought one that was a bit too loud I have a 40W Valvetronix and you can hear it outside with the volume on 4.
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • JonathanAnon
                        • Jul 2012
                        • 457
                        • Ireland
                        Been toying around with this, and the only conclusion that i can come to is to set the volume level on the individual patches and then ignore the volume pot...
                        What I have also noticed is that the volume pot works as follows... nothing up until 1, moves between 0-100% volume between 1 and 2.5, and then stays at 100% the rest of the way up the pot to 10..
                        Why in god's name did they do this? Did they use the wrong pot (maybe linear instead of log?)... I've looked up the line6 forums and a number of people have the same issue, so it's not just mine.
                        • karthur
                          Vizio D65x-G4 Volume changes on its own
                          by karthur
                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                          06-05-2025, 08:13 AM
                          Acer Spider 3 SP313-51N-71U4 Hybrid (2-in-1) Specification for Upgrade or Repair
                          This specification for the Acer Spider 3 SP313-51N-71U4 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spider 3 SP313-51N-71U4 boardview and Spider 3 SP313-51N-71U4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-07-2024, 12:10 AM
                        • crackedprint
                          Sony HCD-HX80R Amplifier Volume Control Problem
                          by crackedprint
                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                          I have tried a Cold Reset as per the service manual.
                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                          I have looked all the way through the service manual and tried many online...
                          01-21-2025, 12:18 PM
                        • BigOof
                          Marantz SR5007 popping on volume change and mute in Direct Mode
                          by BigOof
                          I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                          12-12-2024, 06:15 AM
                        • Storyteller12
                          Samsung Soundbar Q900T Cuts Off if Volume above 30
                          by Storyteller12
                          I have this soundbar and when I turn it on it works until I turn the volume above 30.
                          Then the display show “PROT” protection and shuts off.
                          I can turn it right back on and it works until volume hits 30 again.
                          There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                          I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                          It will play fine for hours with volume...
                          03-21-2023, 12:31 PM
