capacitor balance charging???
  • Rangwan
    • May 2012
    • 14
    • Thailand
    The electronic theory says "connecting capacitor in series will give the higher voltage tolerance, but lower capacitance in the same fashion of connecting resistor in the parallel will give higher power tolerance but lower resistance".
    However, I've got some idea of "balance charging". Giving 3 capacitors of 1F @4.3V each connected in series with 4 pins like
    G|____c1_____|______c2______|______c3_____|+ and charge them like li-po battery. I'm wondered if that will result in 1F capacitor @ 12.6V with no capacitor boomed?
  • 999999999
    • Sep 2006
    • 774
    Re: capacitor balance charging???
    First of all, LiPo batteries should not be charged past 4.2V. If you were to connect 3 x Li-Po batteries in series then yes you can charge the 3 capacitor series to 12.6V but you will not have 1F @ 12.6V, it will be 333mF ( 333,33uF ) at 12.6V.
    Unless you use a (large) high current battery, you should use something like a resistor in series to limit current from the battery while charging the capacitors.
    • Tube_Dude
      • Feb 2011
      • 51
      The resulting capacity of the 3 capacitors will be 333mF or 333.333,33 uF...
      • 999999999
        • Sep 2006
        • 774
        ^ Huh, yeah I mistyped that or something.
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • chth96
          desoldered capacitor is self charging until 0.6 voltage.
          by chth96
          I have an 21 inch CRT TV which is not able to power on.
          I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
          It shows 270V on my DMM.
          So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
          Then I desoldered this main filter capacitor from circuit board.
          But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
          I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
          03-28-2024, 08:56 AM
        • Thomasraud
          Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
          by Thomasraud
          i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
          QUOTED
          -It works on charger (without battery connected-only charger)
          -It works on battery (without charger connected-only battery)
          -& it also works when plugged in battery & charger, but it's not charging the battery
          //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
          and..
          QUOTE
          The IC cannot maintain the input current level
          06-28-2022, 06:47 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
