Insignia BRDVD4 powers on with blue light blinking then shuts off.
  • infringer
    Badcaps Member
    • Sep 2009
    • 244
    • United Frickin States
    I am unsure what is wrong with this unit but ... I will say the transformer seems awfully noisy. Symptoms are the power led blinks blue then shuts off I am curious as to what the cause is but I would be guessing it is likely a power supply related issue because the standby lights work I would say it would be something in the non standby circuit is not getting the proper voltage or something along that line as I said the transformer is louder then I would suspect it would be but the problem with this is it is labeled BCK02 and the company it appears is OQO that makes it and I can find zero information on this unit but I am willing to replace it on a hunch is this normally a high failure item or would there be no power at all and a blown fuse if it were faulty?
    I guess I dunno much but am trying to learn and figured this broken item would be great to learn from... I will likely be ordering a good one with good boards so I could narrow it down to the power board or the main board. Everything is just based upon a hunch currently until I learn some more. But I really have the need to learn a bit more about these circuits.
    I will include a picture of the PSU just for reference in case it helps.
    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
  • selldoor
    Slow Learner
    • 7870
    Re: Insignia BRDVD4 powers on with blue light blinking then shuts off.
    picture is not big enough can you get it to just less than 2mb and also post one of the back of the board
    Re the green caps Teapo or what.
    • 999999999
      • Sep 2006
      • 774
      Agreed, larger pic would be nice and is that a picture of YOURS or only an example pic from someone else? Basic method would be checking whether the output rail voltages seem to be stable and in the range what they are connected to would need... with and without the load(s) connected.
      • infringer
        Badcaps Member
        • Sep 2009
        • 244
        OK got out the good camera and took some pics maybe this would help.
        • selldoor
          Slow Learner
          • 7870
          @999999999 - good spot. not his board then!
          @infringer - so what make are the caps.
          Duff high ripple caps might make the transformer noisy.
          Test the voltages as 999999999 suggests and post the results along side
          the expected results as shown on the board.
          EDIT haha JUNZL - never heard of them
          What is the big cap
          • infringer
            Badcaps Member
            • Sep 2009
            • 244
            Big cap is 100uf BHA Y style CDT03 rated at 105c hrmm so how often do inductors go I guess I am having troubles pinning exactly where the problem lies upon visual inspection all fuses on the main board and the Power Supply seem to have continuity and none of the Caps look like they are in bad shape. But I will have to get out the LCR meter to check for sure I just figured there might be a problem area that would be simplistic to start at without having to go through everything being that there are some old timers with a knack for this stuff on this forum. I'm learning I hope to be able to find them problem areas quickly in due time but for now my hunches are newbieish.
            • infringer
              Badcaps Member
              • Sep 2009
              • 244
              dang LCR meter crapped out I forgot only reads 1 on everything its toasted no fuse and was used on a 300v cap when item was plugged in only rated for 30v pretty useless now but got an extra set of leads for my multimeter if I need it. Oh well live and learn at least that reminds me I still need a new LCR meter dunno why I figured it was 300v hadn't used it for a while and didn't look to check just assumed.
              • selldoor
                Slow Learner
                • 7870
                Cant find anything at all on BHA caps- Id suspect as poor. Unless you have an ESR meter testing the caps will not prove much unless you find one thats shorted.
                Id go for testing the output voltages and see if they are steady. perhaps
                using automotive bulbs to put a load on. That would then give you an indication as to whether the fault lies in the power supply or on the main board.
                Having read the above I would remind you of two simple rules
                Measure voltage with power on
                Measure resistance with power off (at lest 5 minutes)
                • infringer
                  Badcaps Member
                  • Sep 2009
                  • 244
                  15.50 scored me both of the boards so I will test if it is only the power board when I get the boards in a week or better... Until then I will continue to work on a few other projects I got going poor mans projector fix amongst other things also waiting on parts 42" Vizio waiting on a main board. One PS3 here that needs a new sled I'll probably get that one up and running yet tonight. Other then that everything is fixed I think wish I could find and endless supply of broken electronics lol! All is good practice.
                  • infringer
                    Badcaps Member
                    • Sep 2009
                    • 244
                    it was the power board there is a 4 pin component next to the transformer that goes and takes out the big capacitor on the board...
                    • 999999999
                      • Sep 2006
                      • 774
                      ^ What? The only 4 pin component I see next to the transformer is an optoisolator, I'm not seeing how its failure would take out a capacitor nor how the cap would be taken out but not have vented or exploded.
                        Yeah, that does not make sense, the large cap is exposed to the rectified DC from power line by the bridge and could not careless what happen to the OPTOISLATOR for the feedback circuits to maintain the output voltage.
                        Unless he meant the Bridge rectifier (4-pin) next to the Common mode line filter choke.
                          I've had a shorted bridge take out a cap, but only on the second time round (after replacing the fuse)... the first time it seemed to have survived.
                          • cajoeg
                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                            by cajoeg
                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                            02-10-2025, 04:01 PM
                          • TurboTundra
                            PS5 EDM-033 Blue Light 2 Sec then Powers Off
                            by TurboTundra
                            Hi, I am waiting for my uart tool so I can grab an error code and narrow down where my issue is, but I decided to measure capacitors and fuses to insure everything was okay.
                            The PS5 turns on with a blue light and a beep for 1-2 seconds then turns off. I noticed a grey capacitor measures no voltage on standby or input power. Does this indicate a problem with the capacitor or something down on the line? I’m getting 3.3v on input with the red cap next to the grey one, and 5.2v on input with the red cap further away from the grey cap.
                            Thank you for any input...
                            06-10-2025, 08:51 PM
                            Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                            This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                            09-07-2024, 05:50 AM
                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                            09-07-2024, 05:00 AM
                            Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                            This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
