Flux
  • barry wilkins
    • Aug 2009
    • 172
    Flux
    Does anybody know how to make up soldering flux? When I worked for Marconi Avionics ,the rework technician made his own stuff .
    I could do with some nice thin stuff.
    thanks
    Barry Wilkins
  • cmj21973
    • 267
    Re: Flux
    If you really want to make it yourself there are some How To's on the internet.
    If you have rosin soldering flux paste, like the kind from RadioShack, you can thin it with isopropyl alcohol.
    • 999999999
      • Sep 2006
      • 774
      Re: Flux
      How old school was he? Take some pine rosin and mix in enough alcohol to achieve the desired viscosity. The basic idea is you mix a small amount of a reactive (with metal oxides) acid into a carrier, solution suitable for the environment it's used in.
      If it were plumber's flux (not for electronics) for example, put some zinc chloride in petroleum jelly or to back step even further, dissolve zinc in hydrochloric acid to make the zinc chloride. If you wanted it water soluble, the acid goes in water instead and a thickening agent is added.
      Now I'm drifting... most likely the tech used pine rosin and alcohol, that's the mildly activated flux used for decades for hand soldering.
      • PeteS in CA
        • Aug 2005
        • 3576
        • USA, Unsure of Planet
        Re: Flux
        Never seen mix-your-own solder flux ... not sure whether it would be permitted in hyper-controlled manufacturing environments. I'd expect solder flux to be reasonably available through places that carry electronic components.
        PeteS in CA
        • Scenic
          o.O
          • Sep 2007
          • 2640
          Re: Flux
          http://www.dealextreme.com/p/just-wo...ing-paste-4697
          ^ If you wanna try making your own. The reviews and the "forum" posts (bottom of the page) have some additional details.
          • Koda
            • Aug 2011
            • 317
            • Macedonia
            Re: Flux
            Or just buy some
            http://www.dealextreme.com/p/soldering-paste-80g-6168
            I'm using this stuff and it's pretty good.
            BTW can anyone tell me where can I order some liquid flux online??
            Guns don't solve problems. I'll take 12
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Flux
              Originally posted by Koda
              Or just buy some
              http://www.ace4parts.com/Products/83...835-100ML.aspx
              If you search the PN you can probably find it cheaper.
              Mouser carries it but they have the wrong pic so I used that link.
              Frys Electronics usually does to but not on-line so you have to walk-in.
              I use it with a dispenser bottle that has a long needle type tip.
              Mann-Made Global Warming.
              - Dr Seuss
              • 999999999
                • Sep 2006
                • 774
                Re: Flux
                ^ that's the best/easiest way IMO.
                • Koda
                  • Aug 2011
                  • 317
                  • Macedonia
                  Re: Flux
                  Thanks!
                  • ChaosLegionnaire
                    how do u use solid rosin flux?
                    by ChaosLegionnaire
                    i recently bought a block of solid rosin flux from aliexpress. i intend to use it for reflowing cold solder joints and cracked solder joints. but im not sure how im supposed to be using it? do i just break off bits and pieces of it with a knife and put the bits of solid rosin on the bad joint im soldering then bring on the iron?
                    i tried asking google and they pointed me to a headphone forum and eevblog? and they said to just dip the soldering iron tip into the solid block. a small piece of flux will be attached to the soldering iron tip end and im supposed to use that to reflow...
                    06-24-2020, 02:34 PM
                  • chth96
                    Is it good to use chemistronic flux off es835b for flux remover?
                    by chth96
                    I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                    Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                    11-17-2023, 07:25 AM
                    Multifix 425-01 and 450-01 Rework Flux Datasheet
                    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                    - No Clean Formulations
                    - Low residue
                    - Range of activity to deal with different component solderability
                    - Halide free
                    - Suitable for dispensing
                    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                    Both products are supplied in syringes or cartridges for application by dispensing....
                    10-07-2024, 06:02 AM
                  • evilkitty
                    Flux causing high resistance short?
                    by evilkitty
                    Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                    Temp is on the left humidity is on the right
                    i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                    The pin out looking down from the top is (note this is common cathode)...
                    07-17-2024, 09:38 AM
                  • chth96
                    How can I remove flux with the smallest rubbing?
                    by chth96
                    I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                    Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                    Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                    Is there any way to remove flux with the smallest rubbing or without any rubbing?
                    Any reply would be appreciated.
                    11-24-2023, 05:22 PM
