What current rating for a cap?
  • chico1st
    • Jan 2012
    • 21
    Hi there when I am selecting a current rating on a replacement cap how do I determine the current rating?
    So far for any fixes I just choose the highest value that fits but how do you go about deciding if they are high enough?
    Same goes for fuses.
    Without having a schematic some of these things are hard.
  • PlainBill
    • Feb 2009
    • 7034
    Re: What current rating for a cap?
    The best approach is to determine the current rating of the original cap and try to match it. Most capacitors have a two or three character series designation printed near the temperature rating. Look that up and you can determine the specs.
    Here's an example. I just pulled a CapXon 1000uF 25V cap out of the bag of junk caps. On the opposite side it says KF 105°C. Googling CapXon KF series I find that it is rated for a ripple current of 1650 ma, and an impedance of .045ohms. A quick search of Digikey's site shows that the Panasonic FC series and the United Chemi-Con LXZ and LXY series would be a good match.
    PlainBill
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      You look in the data sheet, but caps have more than one current rating.
      For DC you look at Leakage Current.
      For AC you look at Ripple Current but it will be given at some specific frequency. [Typically 100Hz, 120Hz or 100kHz.]
      There will be conversion factors in most data sheets to find the current rating at other frequencies.
      Mann-Made Global Warming.
      - Dr Seuss
      • chico1st
        • Jan 2012
        • 21
        OK I understand the ripple current etc measurements at a high level, but on this data sheet for capxon KF...
        the ripple current is measured in SV? what the heck is that?
        I would assume that it reads as 10V 2200uF cap is 1.65 A ripple? is that right?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Crap brands often have screwy data sheets and CapXon is no exception.
          SV is for Surge Voltage. Not generally shown in data sheets.
          Use the value for WV - That's the industry standard rating.
          Yes 1650 mA = 1.6 A
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Also realize that the voltage rating is a total - as in Ripple Volts + DC Volts.
            - Dr Seuss
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
              Surface Mount Fuses Fundamentals Datasheet
              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
              10-07-2024, 06:07 AM
            • quickname
              Cyberpower 1500AVR UPS repair
              by quickname
              I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
              I decided to verify that the batteries were...
              11-12-2023, 09:57 AM
            • harp
              How to determine smps power rating
              by harp
              So, I have old smps NEC psu, who not work correctly... it has no label table of declaration, and I supose that is from some printer or so.
              The output is 34v.
              Switching element is STR16006
              Mains caps are 2x 470uF/250v
              Output caps is 10000uF/40v
              I dont know a topology, only have interest to know in which way should determine power for what designed for....
              02-24-2024, 03:40 PM
              Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
              The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
              All AP21X2SG-13 AP21X2MPG-13 devices are available...
              10-23-2024, 03:33 AM
