ESR of a cap in parallel with ceramic one
  • ChildOfVision
    • Nov 2011
    • 6
    Hi! I'm sorry if I ask a question that has already been answered, but I couldn't find anything with search.
    I have one question, and there is no better forum than "BadCaps" for this!
    Namely, I am building an ESR meter and I did read somewhere (I really can't remember where) for problem with small ceramic capacitor in parallel with C.U.T.
    Allegedly, certain ESR meters (that uses 100kHz test-signal or something like that) can not measure in-circuit ESR of an capacitor that is connected in parallel with cer. capacitor, as I said. I'm not a beginner in electronics, but I really can't figure out how such a small capacitor with kiloohms of reactance can affect (or even prevent) in-circuit ESR measurements with ANY kind of meters?
    However, I remember of very resolute claims that such a combination of capacitors is utterly hopeless for many ESR meters.
    So if somebody knows something more, please let me know!
    TIA, and sorry for my bad English!
  • brethin
    • Dec 2008
    • 1907
    Re: ESR of a cap in parallel with ceramic one
    The only TRUE measurement of ESR on a capacitor is out of circuit.
    • ChildOfVision
      • Nov 2011
      • 6
      Of course that "The only TRUE measurement of ESR on a capacitor is out of circuit". But, did you ever tried to remove capacitor from PC motherboard, or some VGA card without damaging both capacitor and MB? Well, if you didn't I can tell you it is very, very hard (if not impossible)!
      • b700029
        Banned
        • Sep 2010
        • 640
        It's not hard, many of the members here regularly recap mobos and GPUs. You just need a powerful soldering iron and plenty of flux.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Most people here do that all the time.
          It's not that hard with the right tools and some practice.
          A good share of mobo caps are in parallel with other caps on the board.
          Removing the caps is REQUIRED if they are in parallel and you want to check ESR or capacitance.
          It's not the only 'true' way, it's the ONLY way.
          The total ESR of caps in parallel works exactly like the total resistance of resistors in parallel.
          The total will always be smaller than the smallest value.
          And, how do you know that ""small capacitor with kiloohms of reactance"" isn't degraded and/or partially shorted?
          Mann-Made Global Warming.
          - Dr Seuss
          • ChildOfVision
            • Nov 2011
            • 6
            Yes, you are all right, of course, if I have two or more capacitors (especially elecrolytics) in parallel there is no way to measure ESR of only one cap!
            But, what drives me crazy is what theory is behind that issue with "small ceramic cap" in parallel, I know I read somewhere detailed explanation for this, but I just can't remember where! It is not related to reactance or faulty (e.g. shorted) cap. I found something on EEV-Blog-forum: one member of this forum wrote this: "Unfortunately it's common practise to connect capacitors in parallel, for example on a linear PSU you might have a monster 4700uF capacitor in parallel with a 1uF tantalum and a 100nF ceramic capacitor, the latter both having a very low EAR which will interfere with the result". Does anybody know what EAR stands for??? Is there some kind of "ringing", noise or some kind of uncontrollable oscillations that disturb measurement? Furthermore, many of ESR-meter constructors/sellers "very vigorously praise" their instruments with ability to cope with this problem!
            Such a instruments generally don't use continuous, say, 100kHz sine-wave signal but "just a very short pulse" for testing. So, if someone knows more... please let me know!
            TIA!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              What I think is that on an English keyboard the "A" key is right next to the "S" key and the poster meant to type ESR, not EAR.
              There is a condition where MOSFETs will 'ring' [at a high frequency] and they use small uF caps as a bypass to prevent it but I don't know what that has to do measurements other than the typical caps in parallel problem.
              It doesn't make sense that a short pulse [one shot] measurement would have ringing issues -in the measurement- because 'one shot' is an instantaneous thing and ringing is a continuous thing.
              It could be that what they mean is caps put there to prevent ringing mess up the one shot measurement,, but that is just a caps in parallel problem and it doesn't mean there is ringing occurring during the measurement.
              - Dr Seuss
              • ChildOfVision
                • Nov 2011
                • 6
                Good noticed! I believe this is the case (btw. I never saw keyboard with different character layout, except, in some cases, "Z" and "Y" swap their places).
                No, you misunderstood me: I meant just the opposite - instruments that works with short pulses (better to say: fast series of pulses) actually can do measurements in such a situations.
                For example, see this meter: note 9th "point" - there is explicitly stated "small ceramic capacitor...etc.:
                An Hungarian LCFesR meter
                I already contacted that person, and he is aware of that problem, but he could not explain what is the source of it.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I doubt Dr. Le Hung [the name on the actual schematic] is Hungarian.
                  That meter is a clone of Bob Parker's meter modified to use a different processor.
                  I think the person you contacted stole the design and dosen't fully understand it.
                  - Dr Seuss
                  • ChildOfVision
                    • Nov 2011
                    • 6
                    You are COMPLETELY right! In everything that you said. Dr.Hung lives in Hungary, indeed, but obviously he is not Hungarian. Btw. he asks $$$ for "his" project, so, if you are interested...
                    • Evil Lurker
                      Warranty Voider
                      • Feb 2011
                      • 454
                      EAR = Equivalent Average Resistance?
                      • ttn328
                        • Jan 2011
                        • 12
                        • Vietnam
                        Hi All,
                        The name " Le Hung " is a Vietnamese name. I recognized it just because the language in this name is my native language. I do not have any other thoughts.
                        • hutale
                          • Aug 2013
                          • Hungary
                          Someone notified me about this thread... I think I can explain a little: it is true that Le Hung is a Vietnamese name but I had my studies and degrees in Hungary. I live in Hungary and have a Hungarian citizenship. But from the view of LCFesR meter, all these information are not important. (If you can read in Hungarian then you can read it here: LCFesR in Hungarian).
                          I examined the caps in parallel problem with LCFesR meter: I measured ESR of 1000 uF, 25V cap, its ESR = 45 mOhm. Then I measured ESR of this cap parallel to an 100 nF cap and then parallel to an 2.2 WIMA uF cap, I got the same ESR results. So these small caps are not affecting the result.
                          As to Bob Parker's design, it is referenced in my doc as the theory of ESR measurement but if we examine the 2 designs, the implementation differs a lot, not only because of the difference of processors.
                          • Kiriakos GR
                            Banned
                            • May 2012
                            • 940
                            • Greece
                            You made a page about a product that you are trying to sale and so what ?
                            Why some one to explore your theory when what you made does not have any certification or be tested regarding accuracy from a recognizable source.
                            • chth96
                              Is it possible to test small ceramic disc capacitor with analogue meter?
                              by chth96
                              I read EBOOK of Testing Electronic Component and found that
                              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                              Is it really possible to test small ceramic disc capacitor with analogue...
                              03-09-2024, 10:03 PM
                            • NuclearSpartan
                              Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                              by NuclearSpartan
                              I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                              The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                              I don't see any other visible damage anywhere else on the board....
                              11-14-2024, 02:32 PM
                            • rictechie
                              smd ceramic capacitor use in iphones
                              by rictechie
                              is there a brand of smd ceramic capacitor use in iphones? or they are generics
                              07-26-2024, 08:28 PM
                            • Sparklingx
                              SMD ceramic capacitor capacitance & voltage
                              by Sparklingx
                              what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                              09-12-2024, 01:04 AM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
