Electrostatics
  • Derek23
    • Apr 2008
    • 33
    Re: Electrostatics
    I remember now that long time ago I zapped the PC case with a high ESD (I even saw and heard the spark) when I was about to open it, the PC was unplugged at the time, could the ESD reach the motherboard through the case? The PC is working fine at the time being.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Electrostatics
      Not if the grounding is proper and working.
      Mann-Made Global Warming.
      - Dr Seuss
      • sant1
        MSI H410I PRO WIFI - bios mod, disable overcurrent protection
        by sant1
        Could someone disable USB over-current protection in this bios? Message is displayed over display-port: "Over Current Have Been Detected On Your USB Device!! System will shutdown after 15 seconds to protect your mainboard!!"
        Attached dump to this post.
        Diagnosed and come to a conclusion that PCH is faulty, there are overcurrent voltage dividers (net names OC#0 to OC#7) on USB power lines, dividers output is nearly 0V, PCH is pulling some of them down. Dividers resistors values are ok and data lines and VCC are not shorted.
        Thank...
        12-17-2024, 06:38 AM
      • jimbofz
        technica led 40 e271 not storing channels
        by jimbofz
        made by UMC
        this tv would work fine on scart or hdmi ,
        but no digital channels just the first time install menu
        every time you switched on
        i tried to find how to do factory reset with no luck
        when auto tune was completed it would show how many chans found ,
        then after pressing ok or exit
        tv would return to sby and no chans stored
        i found that menu 1147 would enter s mode
        and the 6th choice on the list was
        : init fac channel ,
        so i pressed ok and ok appeared .i exited s menu and now tv comes out of sby and after...
        02-26-2021, 07:20 AM
      • Trevtron
        Daewoo DT-42A1 not storing settings
        by Trevtron
        A friend asked me to look at this old-school plasma set.
        It runs fine, still has a good image considering its age but every time it is switched off (at the mains) it "forgets" all its settings.
        I've had a good look around, was hoping to find a lithium or backup battery, or a storage capacitor but there's nothing obvious on the psu or main board.
        Anyone had dealings with these? I know it's not worth a fortune but it would be a shame to bin it.
        TIA....
        06-08-2020, 04:28 PM
      • Geosphere
        Help identifying SOT-23-5 regulator marked BFCV on Lucky Miner LV06
        by Geosphere
        I’m trying to repair a Lucky Miner LV06 Bitcoin miner that was given to me.
        It looks like someone plugged 12 V into the 5 V rail and fried the three small adjustable regulators.
        Each regulator is a SOT-23-5 package, all marked “BFCV.” I can’t find any datasheet or reference to that code. The regulators appear to generate 3.3 V (for ESP32), 1.8 V, and ~0.8 V (for the BM1366 ASICs), set by resistor dividers?.
        From tracing the PCB:
        Pin 1 (red) → 5 V in
        Pin 2 > GND
        Pin 3 (yellow) > output ...
        09-19-2025, 12:24 PM
      • Syseng
        Lenovo P14s Gen 5 SVP unlock
        by Syseng
        This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
        The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
        06-22-2025, 07:44 AM
