Seisco RA-28 Control Board
  • GRowe
    • Dec 2010
    This board has blown triacs and what appears to be caps. But when googling the part number I'm not getting an accurate part description or replacement suggestion. The markings read ( VRM .01k630v ). There are 4 on the board, next to the triacs, 2 are blown. I have found the triacs and ordered them but the blue caps or voltage regulators have me stumped . If any body can help with identifcation and suggest replacement parts my sister an brother an law would be grateful ( showers in 60 degree water is no fun from what I here ). Thanks ahead of time for any help.
  • ReverendJones
    Resurgam
    • May 2010
    • 49
    Re: Seisco RA-28 Control Board
    .01uf
    10% tolerance
    630 volt
    A pic would help but they sound like this: http://search.digikey.com/scripts/Dk...me=490-4822-ND
    Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • cmlewis89
      LG 47LB5DF blown power supply board
      by cmlewis89
      Hi folks,
      I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
      09-03-2024, 07:50 PM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
      Linear Garage Door Opener Control board took a crap install a new control board back normal
      I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
      02-08-2025, 06:52 AM
    • redoxy
      Control Board Replacement for 2K display
      by redoxy
      I am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
      The display is Samsung LTM270DL07.
      I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
      I am looking for inputs on what board could potentially be used for my display.
      Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
      Also attached is a technical...
      03-14-2023, 08:52 PM
