Power-One solar Inverter driving me NUTS!!!
  • mitsu2k
    • Aug 2013
    • 219
    Re: Power-One solar Inverter driving me NUTS!!!
    I don’t want to get my hopes up because I think I tested it before and it was fine. So it may have blown from the megger testing
    • mitsu2k
      • Aug 2013
      • 219
      No luck. Still that stubborn GFI LED
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8146
        Dang. Back to the drawing board. Would have been nice to have it fixed. I am out of ideas right now.
        • mitsu2k
          • Aug 2013
          • 219
          I hear ya! Well, if you get any more ideas please don’t hesitate. You have been incredibly helpful and I don’t know how to thank you enough. I know you spent hours of your time in this. I do very much appreciate you!!
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8146
            One more I got. You said you changed that CT? Is it installed facing the right way? What I mean its like a current clamp, face it the wrong way and the measurement is negative.
            I think the appreciation goes both ways. Plus you were delivering answers as fast as we asked the questions and you spent many hours as well... never stop learning and thanks to you too for hanging in there when things got tough! I like a little challenge once in a while. Specifically something that is on the rare side of things. It would be nice to figure this out, but without a schematic things aren't looking great as we running out of options.
            • mitsu2k
              • Aug 2013
              • 219
              Hi CapLeaker, by the way I love that handle!! Anyhow, yes I am sure the CT device is installed the correct way. I took extra care with that and made sure I had the new one in hand before removing and unwinding the old. My memory is failing so I did not trust myself and wanted to make it as exact as the old one was.
              I did make a mistake with that zener however. I had mistaken it for an 18v zener and replaced it with that value. However I tested the adjacent ones and they measure at 12v. Some other data sheets confirmed this. Not sure if it will make any difference or not but I went ahead and replaced it with a 12 V. However, when I installed it and powered it on, unfortunately, I did not beat the sun and it will not power on because it's dark now. Now I'll have to wait until the morning, oh well, I suppose I need a break anyway. We all do.
              • mitsu2k
                • Aug 2013
                • 219
                On another thought, I recall reading in the manual about the Riso low GFI error. I read that this error of the GFI LED will come on at below 1 megaohm. This would indicate a leakage to ground on the PV side. The way, I understand this, is that the inverter is made to work on 1 megaOhm or above. When I power it on, and it does the RISO check, it comes back at 20 megaohms which is good and normal. So I guess what my point is, the 1 megaOhm that I am reading with the megger when the second board is connected may be normal.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8146
                  I am not so sure about this. There is no real guideline one fits all approach. To me anything that’s 1 MOhm or below inside the inverter, is garbage in my book, but then I don’t know your inverter either.. If you look for a specific value, you find these are all over the place. But generally speaking the 1 MOhm is what most people go by unless they only deal with one unit or know it well enough to know the exact threshold, ins and outs, etc.
                  What really gets me is that the GFI error comes on right away, but yet no error codes. That leads me to believe it may be something the computer doesn’t monitor. Some older units have a 1A fuse installed between neutral and earth ground, but I don’t see it in your unit. Next on the list are the MOV’s and they all measureing fully open, no resistance at all. Could be leaking caps, IGBT, diodes, a bad relay, but so far nothing.
                  So all I can come up now with is this: these charcoal burnt spots. Is there maybe a via or trace where the black goes from the hv part of the relay to somewhere as carbon is conductive. Just very little moisture on the exposed black PCB can give you a reading on the DMM or better the Megger. Try it with 99%IPA and you will be surprised.
                    • Jul 2011
                    • 6039
                    CapLeaker
                    You might have something hear me hear me out what if you have a relay or more than one relay that has carbon tracking inside of it but it not enough to test for but enough for the micro computer to see because we do not know exactly how it doing it’s self test and where it is getting it test data from ( you might just have to replace them )
                    You could also have a situation where if there is an issue with the IGBT module or ic chips are having internal issues and like I said we do not have any idea what the self test is looking for unless you find a testing procedure that is this particular IGBT ic chip the only thing you can do is replace them
                    As far as the capacitors are concerned how to check them for leakages under load situation I am not sure exactly how you would do this without just replacing them because we do not know exactly what the self testing is looking for
                    I once had a machine that that had an IO module fault and even technically support had not seen this issue before so they were not sure exactly what to replace except for the fact that a secondary Servo monitoring module had no interface indicator lighting up and the main Servo main switching power supply was showing all systems were functioning correctly
                    Well not exactly this micro controller had different levels of fault tolerance and the main Servo controller switching power supply system interface was not reporting properly the fault issues because it was that system fault and once I replaced the Servo switching power system the secondary monitoring system came back on line and finally did the complete self testing procedure and the machine came back on line *****
                    I posted this about the machine that I had to repair and how a self testing process can be derailed because of something else that really is not the issue and what it thinks is wrong and I have wondered if this is what might be happening here with this inverter ( the machine case issue I disabled the “ enable signal to the Servo switching power supply and forced it recognize a different set of faults because the self testing process hauled and it could not reset it properly to start from the beginning and do the self testing properly ) now how do this on this inverter I have no clue what and how to proceed with next I wish I did because I have been following this post from the beginning I wish I could tell what should be next to try
                    • mitsu2k
                      • Aug 2013
                      • 219
                      CapLeaker, I agree. With you in that it is very strange that the LED comes on immediately before any tests are performed is strange. I saw some videos online where the red LED did not come on until after it performed. It’s RISO test. I do need to mention that there is actually a third board on the unit. I guess I assumed you guys already knew this from the pictures but that board appears to be the computer board and there is a ton of SMD components on there. I wouldn’t even know where to begin on that board, but my gut tells me that it is likely not the issue. However, anything is possible.
                      Thank you SAM. You as well have been a great help. I think all of us are on the same page in feeling that it is erring out before it gets to its computer checks. I have tried my best to find bad components and clearly I am missing something or else it would be fixed by now. I will have to be more thorough. I wish I could identify those seven modules that are clamped to the heat sink. They have no markings on the top. I have lifted the clamp a little bit to look and could not see anything. If I can identify them then I could figure out how to test them.
                      • mitsu2k
                        • Aug 2013
                        • 219
                        SAM, Thank you! You as well have been a great help. I think all of us are on the same page in feeling that it is erring out before it gets to its computer checks. I have tried my best to find bad components and clearly I am missing something or else it would be fixed by now. I will have to be more thorough. I wish I could identify those seven modules that are clamped to the heat sink. They have no markings on the top. I have lifted the clamp a little bit to look and could not see anything. If I can identify them then I could figure out how to test them.
                        By the way, all the black relays are new. As for carbon, yes that is suspicious as well but I could not see any small traces that might be shorted by this carbon. That’s why I was looking for other layers within the PCB. For good measure I will go back and read this entire thread again. I feel the answer may be right here and I am overlooking something. Wouldn’t be the first time. Lol
                        • mitsu2k
                          • Aug 2013
                          • 219
                          Here is what I am referring to as the computer board.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8146
                            Hmm… are there a few posts missing? At least one of mine is.
                            • petehall347
                              • Jan 2015
                              • 4426
                              #114
                              yes posts are missing .. took me 24 hours to log back in .
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8146
                                I can’t log in with FireFox period. It just rejects me, Used a different browser and all is good, besides I have to keep login back in once in a while, even so “remember me” is ticked off.
                                • petehall347
                                  • Jan 2015
                                  • 4426
                                  #116
                                  same here wont stay logged on . it was telling me wrong password entered for 24 hours and locked me out .
                                  anyway the missing posts . one or 3 were mine and was looking at what actually drives the fault light on am guessing something like mcu and transistor etc . then was going to try and see what triggered the fault for the mcu to turn on the light . guessing it will be a high or low state trigger of some kind .
                                    • Jul 2011
                                    • 6039
                                    It is going to take some time to get used to this new system for the BadCap forum but I do not which one is worse a website that was getting really hard get on or a new website that you have to get use to the format
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8146
                                      I agree... Well, now I am able to sign in with Fire Fox no problem. lol
                                      Anyway... at this state I think it is almost impossible to figure out unless we have a working unit or schematics. Unless we get a lucky shot.
                                      • mitsu2k
                                        • Aug 2013
                                        • 219
                                        Wow, took me a while to sign back in also. Anyhow I traced one of the pins of the GFI LED directly to some optocouplers. Two of them. It seems like the VCC pins on each of the two optocouplers in the photo are connected directly to one of the LED pins that I traced. Not sure if this is normal or not. I have to wait for my daughter to help me because I need 4 hands to test these using two multimeters. Photo attached
                                        • petehall347
                                          • Jan 2015
                                          • 4426
                                          #120
                                          looks like maybe switched through negative then and using same positive as the optos .
                                          • Francesc V.
                                            Trying to repair a MPI5.5kW solar inverter
                                            by Francesc V.
                                            My parent's solar inverter died after 5 years of good service.
                                            It's a called hybrid inverter:
                                            - It can go with or without batteries
                                            - It has 2 MPPT (8 330W panels in 2 strings) -> 5280Wp
                                            - A 20kWh lithium battery previously used in a Nissan leaf (14S at 4.1V max) -> 57.4V
                                            Panel is showing error 17 and the battery connection has disappeared. On the other hand, is delivering load, MPPTs are working and it's exporting energy to the GRID. Not that "bad".
                                            Let's open it......
                                            I see that 150A fuse is gone and the...
                                            03-07-2023, 06:17 AM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
