Power-One solar Inverter driving me NUTS!!!
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by Francesc V.My parent's solar inverter died after 5 years of good service.
It's a called hybrid inverter:
- It can go with or without batteries
- It has 2 MPPT (8 330W panels in 2 strings) -> 5280Wp
- A 20kWh lithium battery previously used in a Nissan leaf (14S at 4.1V max) -> 57.4V
Panel is showing error 17 and the battery connection has disappeared. On the other hand, is delivering load, MPPTs are working and it's exporting energy to the GRID. Not that "bad".
Let's open it......
I see that 150A fuse is gone and the... -
by sam_sam_samI just seen this item is this a good idea if why and if not why not
Here is the website link to it
https://www.ebay.com/itm/40599879518....c101465.m3507 -
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... - Loading...
