Power-One solar Inverter driving me NUTS!!!
  • petehall347
    • Jan 2015
    • 4426
    #181
    REF3033
    https://www.s-manuals.com/smd/r3
    https://allegro.pl/oferta/zrodlo-odniesienia-3-3v-ref3033-r30d-sot-23-4069-12780645910
    • petehall347
      • Jan 2015
      • 4426
      #182
      something strange happening in my last reply .. second link again here .its just an example and not saying buy from there
      https://allegro.pl/oferta/zrodlo-odn...69-12780645910
      • mitsu2k
        • Aug 2013
        • 219
        the chinese translates to . You must report any pirated pictures. Any problems in pirated stores.
        L O L, I just snapped that picture off the web because it was exactly like my component and a better picture of it
        • mitsu2k
          • Aug 2013
          • 219
          No worries Pete, I got it on my shopping list. Thank you again!!
          • mitsu2k
            • Aug 2013
            • 219
            Is this an SB or S8?
            • petehall347
              petehall347 commented
              Editing a comment
              looks like a B and google agrees with me .
          • mitsu2k
            • Aug 2013
            • 219
            But this photo looks like 8. Can you send me a link to what you googled please?
            it is SOD-323
            • petehall347
              • Jan 2015
              • 4426
              #187
              here but its not reading the text now
              https://lens.google.com/search?ep=cc...VsbCxbW11dXQ==
              • mitsu2k
                • Aug 2013
                • 219
                Pete, I ordered both anyway one is 50v and the other is 30v. That's the biggest diff I can see.
                Mouser order placed. Will arrive Tuesday. Never been so nervous. Lol
                • petehall347
                  • Jan 2015
                  • 4426
                  #189
                  2n might be RLSD32A361C tvs esd protection . might not as well . cant find any pics .
                  • mitsu2k
                    • Aug 2013
                    • 219
                    What is this component? Anyone know? I think it is a zener but it measures 1v. I cannot make sense whether that is a WI or W1
                    • mitsu2k
                      • Aug 2013
                      • 219
                      SUCCESS!!! Replaced those burned components and a few more that were shorted on the logic board and this is the result. I want to give a big shout out and THANK YOU to CapLeaker, SAM_SAM_SAM and Petehall347 for all your help and dedication. You guys are absolutely amazing and I could not have done this without you. THANK YOU!!
                      • ssrkh
                        ssrkh commented
                        Editing a comment
                        so sad u didnot mention me
                    • petehall347
                      • Jan 2015
                      • 4426
                      #192
                      glad you got it fixed .well done .
                        • Jul 2011
                        • 6039
                        I glad you got it fixed
                        So what were all of the bad parts did you have to replace that was either burnt out or bad when tested
                        I am very lazy to go back and read all the posts that were written about this issue with this inverter
                        • petehall347
                          • Jan 2015
                          • 4426
                          #194
                          the parts were in the area i suspected earlier on .i have never seen one of these units in front of me so i could only guess the general area like around an mcu. i should have said look for the clock crystal that's there in most cases next to them .would have been good to know what caused the damage whether it being bad design or bad quality parts etc etc . .
                            • Jul 2011
                            • 6039
                            I was wondering the same thing
                            • mitsu2k
                              • Aug 2013
                              • 219
                              They were right next to the crystals. The parts I replaced were:
                              3 mosfets (SOT-23) One was burned and the other two were shorted.
                              4 shorted diodes (One was burned) (SOD-323)
                              3 zener diodes (should have been SOD-323 but I used through hole wire leads instead)
                              I had trouble with the zener diodes trying to figure out the marking whether it was "WI" or "W1". neither of these made any sense because my research showed the WI is 12v and W1 is 2.7v but when I found some good ones on the board and tested them, they measured 3.4v and 3.7v. So I had some 3.6v through hole zeners so I just bent the leads and soldered them to the pads. Looks like it did the trick.
                              • mitsu2k
                                • Aug 2013
                                • 219
                                Yes Pete you kept asking for the model of the controller. I should have paid more attention but honestly that board intimidated me and I was too lazy to scrape off all the silicone they coated the board with. I should have listened to you earlier but I had tunnel vision and did not think the problem was on that board. Obviously I was wrong and I learned a lot from you and the other gentlemen. Next time I need to keep an open mind, get over my fear, and be more thorough with visual inspection.
                                • mitsu2k
                                  • Aug 2013
                                  • 219
                                  Here are some photos. One is before removal of the components and the other is after I removed them and cleaned up the pads.
                                    • Jul 2011
                                    • 6039
                                    That is a lot that went wrong with this inverter wow
                                    • mitsu2k
                                      • Aug 2013
                                      • 219
                                      Yes the two burned components (one diode & one mosfet) were open. The rest of the components in the other side were shorted). I suspect something shorted and went down the line and fried everything else. It ran all day yesterday with no problems and still running good now.
                                      • Francesc V.
                                        Trying to repair a MPI5.5kW solar inverter
                                        by Francesc V.
                                        My parent's solar inverter died after 5 years of good service.
                                        It's a called hybrid inverter:
                                        - It can go with or without batteries
                                        - It has 2 MPPT (8 330W panels in 2 strings) -> 5280Wp
                                        - A 20kWh lithium battery previously used in a Nissan leaf (14S at 4.1V max) -> 57.4V
                                        Panel is showing error 17 and the battery connection has disappeared. On the other hand, is delivering load, MPPTs are working and it's exporting energy to the GRID. Not that "bad".
                                        Let's open it......
                                        I see that 150A fuse is gone and the...
                                        03-07-2023, 06:17 AM
                                      • x_orange90_x
                                        Vizio E55-E1 bad backlights or bad inverter?
                                        by x_orange90_x
                                        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                        I don't know how exactly to test the inverter itself. Is it...
                                        01-29-2025, 09:24 PM
                                      • Gentian
                                        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                        by Gentian
                                        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                        03-06-2023, 07:07 AM
                                      • valvashon
                                        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                        by valvashon
                                        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                        01-04-2024, 01:44 PM
                                      • caseyjay_48
                                        Sony KDL-46BX450 Inverter Troubleshoot Logic
                                        by caseyjay_48
                                        I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                        I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                        09-23-2022, 08:08 PM
