Artist seeking to tinker with electronics safely
  • Hypersapien
    • Oct 2023
    • 5
    Howdy folks! I'm an artist in the video game industry, and my job entails making a lot of mechanical and sci fi assets. I thought it might be a good practice to start disassembling some electronics to be more familiar with how real electronics are manufactured and assembled, which is how i found my way to these forums.
    When I started researching what tools I might need, I quickly encountered the warning "Some devices can maintain a potentially lethal charge in their capacitors, even up to years after last being powered on", which was enough of a scary thought for me to slam on the breaks and seek some education before actually taking anything apart.
    My electronics knowledge is quite novice- I know the words 'capacitor', 'resistor', and a handful of others, but i'd struggle to give a definition of what those things do.
    I've been seeking out youtube videos on this subject for a while, but have yet to reach a level of knowledge where I feel safe poking around electronics. I bought a couple of old VCRs at my local goodwill that I thought would be interesting to look inside of, and I also have a blender that recently died- What is the danger level of capacitors inside of devices like these?
    At the suggestion of a friend, I purchased a multimeter, but I haven't yet learned which of its functions I should be using, or where I would I apply the probes to safely navigate around the guts of these electronics. I also ordered a capacitor discharging pen tool that I'm hoping will be useful.
    If any one has any words of wisdom or useful resources on these safety concerns I would greatly appreciate it, thanks for your time!
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Re: Artist seeking to tinker with electronics safely
    If the VCRs have been unplugged for a while, you should be fine. However, it's always a good idea to take a look at the voltage rating of the capacitors. For example, 50V=safe, 400v=stay away. You can use gloves to avoid touching both pins of the 400V capacitors. If you want to check how charged the capacitors are, put your multimeter on 500V DC (the V with one straight line and one dotted line) and put the probes on both sides of the capacitor (being careful not to touch the metal parts of the probe or to touch one probe to both sides of the capacitor).
    If you want to get a hang of the function of electronic components, I'd recommend some YouTube videos like Bigclivedotcom's Simple guide to electronic components or The Defpom's Electronics Basics Series .
    • Hypersapien
      • Oct 2023
      • 5
      Thanks for that info! Any particular kind of gloves I should be using? When I tried to google that question the results I was seeing were like $500 gloves for high voltage work...
      And as far as the machines i'm going to disassemble, Goodwill keeps them on a shelf with electrical outlets nearby so people can test them before purchasing, so they could have been powered on as recently as i purchased them, but they've been sitting on my garage workbench unpowered for a month.
        • 31260
        you dont need gloves,
        just dont touch high voltage capacitor pins until you meter them
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          The most important advice I can give is to just NOT open electronics WHILE they are plugged it. Should be obvious really... and in your case, that probably won't happen either, since you're not looking to repair/troubleshoot these, but just to open them for fun / learning purposes. So you should be relatively safe. Most consumer / household electronics (except for Microwaves) don't usually have big enough caps to store enough energy to kill. Jolt / shake you up / give you a scare? - YES. The worst, IME, is a fully (or nearly full) charged 450V capacitor from a PC PSU or TV, going from one hand on the circuit board, through the body, then out the other hand and back to the circuit board. Perhaps a charged CRT TV/monitor tube might be worse than that, though I haven't had the "pleasure" of experiencing one of those yet.
          Actually, what's more dangerous if you get shocked is that you might yank your hand back... and if you have it near any kind of sharp metal piece, you can get a nasty cut... or hit the back of your hand (elbow) in whatever is behind it. That's about it, though.
          Really, just don't take apart microwave ovens quite yet. Or fridges (high pressure freon.) Or very VERY old CRT TVs that don't have tube implosion protection (so anything older than a 60's or 70's TV set, I think... maybe even 80's??)
          *EDIT*
          Watching the early videos on Electroboom's channel on Youtube can also be educational... and funny. Highly recommended if you've never seen them or that channel. He also has 1 or 2 videos on what is/could be and what isn't a dangerous / lethal shock & electrocution. A lot of people *everywhere* say and think, it's the current that kills, not the voltage... but it's actually a lot more complicated than that. It's more about the energy and the time it can be delivered in... which turns us back full circle in that most consumer electronics simply don't have large enough capacitors to be that dangerous.
          • Hypersapien
            • Oct 2023
            • 5
            Thanks for the words of advice. I dont see myself graduating to larger devices, I'm only looking for artistic inspiration afterall. I'm also looking for things that haver interesting moving internal parts, not just circuit boards- that's why I went with VCRs to start.
            I'll check out electroboom, thanks!
            • CapLeaker
              Leaking Member
              • 8342
              Maybe look into automotive if you want to see electronics working together with moving parts. There is ABS breaks, power steering, fuel injection and many others.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                Inkjet printers too, and those should be both plentiful and cheap/free to find.
                Craigslist FREE section is a good source for them, at least in my area. This is how I also got some of my broken electronics that I fixed.
                • Hypersapien
                  • Oct 2023
                  • 5
                  ... If you want to check how charged the capacitors are, put your multimeter on 500V DC (the V with one straight line and one dotted line)...
                  The multimeter I bought doesn't appear to have a 500V DC setting. Should I assume the 600V is the one I should use?
                  Also, does it matter which probe is connected to which side of the capacitor, or is it interchangeable?
                    • 31260
                    600 setting,
                    leads will work both ways - not that it matters but if you get them the wrong way it just puts a "-" sign infront of the reading
                    • stevediaz
                      • Dec 2023
                      • US
                      Your approach of getting a multimeter and a capacitor discharging pen tool is a great start. When using the multimeter, focus on functions like resistance and voltage. Before poking around, make sure to discharge capacitors using the pen tool.
                      • ClockChip
                        Isopropyl alcohol as a cleaning agent?
                        by ClockChip
                        Hello All,
                        I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
                        The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
                        03-16-2024, 12:10 PM
                      • peterwang
                        Samsung NP750QGK-KG3US BIOS program error seeking help
                        by peterwang
                        PCB:BA41-03025A BA92-25486B
                        I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
                        08-14-2025, 08:15 PM
                      • proton32064
                        General Question- Electronics from 70's and 80's
                        by proton32064
                        I have a question since I am new here and I don't know if this is the right forum to ask these questions or if I am wasting your time.
                        I am 67 and have a lot of Radios and Electronics I grew up with which puts a lot of them at 50 years or older.
                        A lot of the capacitors are obviously bad but this is my problem.
                        An example would be the Panasonic RC-7469 Clock Radio and the Panasonic RF-888 Radio.
                        I have others like a Canon L-162 Nixie Desktop Calculator 110AC, etc.
                        I have the Service Manuals to some of these and other electronics I have and grew up with and...
                        05-09-2025, 05:16 PM
                      • Galindrada
                        Electronics Books
                        by Galindrada
                        Good evening team,
                        I've been trying to learn electronics since the beggining of the year. My main goal is to fix broken consoles/laptops. It has been a very fullfilling journey and fortunately I've found my way around and I've already fixed a few of them.
                        While there's a lot of info online (this forum as an example) I would like to gather a few suggestions about books on electronics. I've already attempted to read a few ones, but to be honest I haven't found anyone that suits what I'm looking for. As an example "The Art of Electronics" is amazing, but there's...
                        11-27-2023, 05:16 PM
                      • Adenitz
                        Electronics failing when supplied with lower voltage
                        by Adenitz
                        Hello guys,
                        recently I watched Richard's video on YT (Learn Electronics Repair channel) with an explanation why lower input voltage than rated can also kill electronics components.
                        The vide can be shown here.
                        Now, I would like to learn more and I'm not sure that I understood exactly why this is happening.
                        It is clear to me that PWM chip will keep MOSFTES switched On longer (duty cycle is longer) and that they will dissipate more heat. I think this is not the main reason because MOSFET can probably work switched on for a long time. It is also possible that output...
                        12-26-2022, 12:45 AM
