What size is this resistor?
  • survivalbloke
    • Aug 2021
    • 302
    I'm used to seeing impedance specs which I understand, but I'm not understanding anything about this resistor besides the package, 0201. For reference, this is beside the backlight driver on A2289 macbook, board 820-01987.
  • petehall347
    • Jan 2015
    • 4430
    • United Kingdom
    Re: What size is this resistor?
    i guess the 102 is 1k .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      You need to show context in the schematic. I think it's just a 0Ω dummy shunt/jumper.
      • survivalbloke
        • Aug 2021
        • 302
        Sorry - here you are!
        • redwire
          • 3912
          It's a 0Ω resistor. LP8548 boost converter for LED backlight requires at least 1.2V on the EN pin to turn on.
            • 31139
            it's pretty clear to me.
            0 ohms
            1/20th of a watt - would of been nicer in decimal, fucking apple!
            5% tolerence - cheapest variant, fucking apple!
            MF Metal Film - none of that carbon bullshit
            0201 = too small to work with unless you have a microscope!
            • survivalbloke
              • Aug 2021
              • 302
              0 ohms
              This had me laughing, not gonna lie!
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • Hw31
                Intel 12700k missing resistor and cap value/size
                by Hw31
                Does anyone know the value/size of the cap and resistor where the thumb is?
                Thx...
                07-23-2024, 04:00 AM
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
