exploding TO-220...TO-247... but what about TO-3?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    We've seen plenty of TO-220s and D-PAKs and DIP8s exploded from abuse...also TO-247s...
    But has anyone seen a TO-3 explode? Are they capable of exploding or is the hermetic seal sufficient to keep the carnage internal?
    Of course there are several variants of TO-3's like the aluminum and steel variants, but has anyone seen either blow up? Frag bomb?
    How about TO-66?
    I suspect the cap and weld are the weak points, but don't know.
    BTW, I'm trying to understand how someone blew up their TO-3 on reddit ...
  • petehall347
    • Jan 2015
    • 4448
    • United Kingdom
    Re: exploding TO-220...TO-247... but what about TO-3?
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      I don't have any/there aren't any!
      And the reddit picture is very suspicious, so I will not include it here.
      • redwire
        • 3912
        Metal can TO-3, TO-66 have nothing to explode really.
        I have seen one where a bonding wire (must have blew off the die) inside started an arc to the lid and made a hole in it.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          That's what I would have thought... it's not like a epoxy (usually organic material with carbon atoms) that gotten hot enough it would burn... the welding indeed is possible.
          Makes one want to go back to metal cased TO-3/TO-66's no? heh.
          • CapLeaker
            Leaking Member
            • 8349
            No exploding TO-3 that I can remember. They just failed. Very very rare occasion that the lid comes off.
            I think you should do another thread asking about which device explodes most violently.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8706
              Feel free to do so! (and maybe a howto!)
              I just recalled my TO-3 smoking was no smoke. It just up and died without a trace.
              If anyone was wondering about the failure, it was in the amateur radio subreddit - someone had their Yaesu FT-101 fail spectacularly and there was some carnage with their TO-3 inverter transistors. While I don't doubt these can fail, the way it did fail seemed suspicious until they dissemble it further. The photo looked like the TO-3 flange *bent* -- this is simply incomprehensible, but the angle of the photo shot was not helping. Perhaps something under the TO-3 exploded with enough force to... bend the TO-3? No, no, no...
                • 31269
                there is no oxygen in them - so there is nothing to expand and burn
                they go open or short often enough though.
                • redwire
                  • 3912
                  Ultimately the bonding wires are the fuse. TO-3 for inverters can have double or triple to get say a real 40A rating, see BUX22 die shots and it is dual die as well.
                  Really old power transistors from the 1970's did not use bonding wires, but they used tabs for high current. The PCB connections to the pins can also get hot and fail.
                  I say bullshit on the warping, TO-3 has an extra heat-spreader plate inside.
                  Crappy plastic packaged parts i.e. TO-247 can't compete.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Dammit, but I don't care: I just head another anecdotal story on face***k that someone melted a TO-3 transistor due to omitting the snubber network. I suspect this is a secondary failure where the flyback caused arcing and causing the transistor to turn on all the time...and then causing meltdown of the die and allegedly flange warping???!!! But did anyone see this posting and can verify? Pictures or it didn't happen?
                    I do not have face***k so I have no idea...
                      • 31269
                      how could the base warp - it's bolted to the heatsink
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        agreed, but if we're wrong, hopefully someone here has seen that FB picture and prove it.
                          • 31269
                          given the thickness of the pins and the usual termination methods - i call bullshit.
                          they are usually soldered to wires using leaded solder that would melt and dry-joint or they are in sockets that have current limits.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            Okay. The face***k posting has been debunked, it was a plastic device after all, apparently a TO-220. These plastic units explode all the time, specifically TO-220s, and I've had my share of exploded TO-220 units
                            Now it's just the reddit post that needs to be squared away with an allegedly bent TO-3 flange. Again I hope the poster coughs up more details or it really did not happen the way that it was stated...
                            • CapLeaker
                              Leaking Member
                              • 8349
                              Did I already mention… I hate Facefook!
                              • redwire
                                Exploding motor cap on Ryobi electric pressure washers - product recall
                                by redwire
                                Exploding motor cap on Ryobi electric pressure washers.
                                Recall is for 764,000 units and 16,000 sold in Canada.
                                "TTI Outdoor Power Equipment has received 135 reports of capacitors overheating, including 41 reports of explosions, resulting in 32 injuries and/or fractures to the fingers, hands, face, and eyes."
                                Broken bones? Shrapnel In your face? Never reach for the on-off switch, just run away!
                                Found this pic on Reddit, cap looks like a plastic housing electrolytic? with big rubber bung at the end.
                                Safety vent too expensive! DELETE DELETE
                                08-31-2025, 11:03 AM
                              • cheebster
                                LG OLed Main Board Swap Upgrade Compatibility
                                by cheebster
                                Hello ! I'm taking a chance here to see if there are any LG techs or anyone who messed with LG OLed panels here that know anything about my issue.
                                So i have an LG panel, it's from a OLED65B7 model. Second TV is a lg OLED65BX (new model) with a cracked panel.
                                So i took all the guts, and put it on the B7 Panel. It *somehow* works but image is not ok, it seems the reds/yellows/blacks are messed up.
                                I have heard (a quick google search shows many reddit users doing sucessful swaps) and i've done it myself, you can use a board from a B7/B8/B9, C7/C8/C9...
                                01-09-2023, 07:49 AM
                              • Technomancer
                                Playstation 2 PSU zener diode values (ZD1 and ZD3)
                                by Technomancer
                                I am attempting to repair a PS2 PSU that died a horrible death when the Q1 mosfet shorted. There are 2 diodes that I believe got taken out along with the main fuse when that mosfet went, ZD1 and ZD3. From the searching/reading I've done on the topic, ZD1 can look like its failed when a continuity check is done in circuit as there is a .25 Ohm resistor in parallel with it. I'll pull ZD1 out of circuit to check it to be sure. ZD3 I'm pretty sure is gone as its showing a 0 voltage drop on my meter in both directions. (Just pulled and checked them both and they are blown).
                                Does anyone...
                                02-11-2022, 03:51 PM
                              • Uranium-235
                                Gigabyte exploding power supply
                                by Uranium-235
                                Gigabyte PSU's aren't the best but this is ridiculous.
                                09-07-2021, 06:20 PM
                              • re-atari
                                Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                by re-atari
                                Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                02-03-2025, 06:49 PM
