Hakko 808 too hot!
  • 4tified
    • Jun 2008
    • 55
    Re: Hakko 808 too hot!
    Originally posted by Toasty
    I attached the pics so we don't lose them (like the last 12 hours did.)
    Please upload direct to forums. Use the Advanced Editor and Manage Attachments.
    Toast
    Sorry bout that, I only saw the url link, I'll attach them next time. Thanks!
    • severach
      • Aug 2007
      • 1055
      T2: AC03D TRIAC, possibly NEC AC03DJM, no phantom shorts
      IC2: NEC C324C Quad Op Amp
      IC1: NEC C1701C
      sig files are for morons
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        IC1: NEC C1701C
        ad up to the 2 ic's to get the full number.
        upc324c
          • 31304
          probably a generic lm324
          • 4tified
            • Jun 2008
            • 55
            I think I'm just going to purchase the control board. I'm tired of pissing around with this thing. Too many repairs to do and without my 808, I can't make any extra money.
            Thanks for the help guys.
            • EasyGoing1
              The best way to drive a heating element?
              by EasyGoing1
              I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
              What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
              This is the general setup that I have now.
              This is what the...
              01-25-2023, 11:29 AM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              by mikey5791
              Hi to all forum members,
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
